Possible stripped thread?
Old Mar 7, 2020 | 06:16 PM
J Cloud's Avatar
J Cloud
Default Possible stripped thread?
2001 C5 corvette base. Doing plug swap during header install. it’s the front plug on the passenger side. plug came out fine no issues. well as i’m screwing it in it gets harder and harder to screw in and sticks out further. my question is. is this black buildup stopping the plug from going in or is it stripped somewhere? i haven’t tried to clean it up yet i’m just asking on here for help. here’s a picture of what it looks like.
Old Mar 7, 2020 | 07:45 PM
frodo84's Avatar
frodo84
Uneducated autodidact
What do the threads on the plug that came out look like?
Old Mar 7, 2020 | 07:50 PM
J Cloud's Avatar
J Cloud
honestly couldn’t tell ya. came out with no struggle and i tossed them like an idiot. i’m going to try a rethread kit since the plug clearly isn’t going in properly then if that doesn’t work i’m going to buy some 243s locally
Old Mar 7, 2020 | 09:18 PM
69's Avatar
69
Cruise-In VI Veteran
Looking at the threads, looks like the brown color is some sort of debris in/on the threads (oil coke?)...before trying a rethread kit, I would use a tool called a spark plug thread chaser, (NOT A THREAD TAP as this tool cuts threads). And the thread chaser cleans the threads but does not cut the threads...
Use the spark plug thread chaser by hand, take your time and after applying that elbow-grease you may be good to go for installing the plug and torqueing it to specs.
Cheers,
Goose
Old Mar 7, 2020 | 09:30 PM
J Cloud's Avatar
J Cloud
Cheers,
Goose
thank you for the input. i’m pretty sure the spark plug is cross threading or something. it’s easy going in until about 10 or 15 passes right with my socket wrench then it’s very tight and hard getting it screwed down. i’ll buy both thread chaser and a rethread kit and see if either it works
Old Mar 7, 2020 | 10:14 PM
walleyejack's Avatar
walleyejack
threads on head look striped on the left side of pic,, get a thread chaser.. lots of sticky oil and run a tap through it.
sticky oil like cam lube or something along that line
Old Mar 7, 2020 | 10:48 PM
J Cloud's Avatar
J Cloud
got it to seat all the way down with the chaser there was a lot of buildup
Old Mar 7, 2020 | 11:00 PM
walleyejack
good job. well done
Old Mar 7, 2020 | 11:16 PM
J Cloud's Avatar
J Cloud
thank you guys i really appreciate it
To Possible stripped thread?
