Reassembly Questions
1. Is there supposed to be a coolant crossover hose/tube on the rear? When I disassembled everything, there was no tube, just blocks that screwed down in the ports to close them off. However, I found what appears to be an air tube behind the engine that wasn't connected to anything. It connects perfectly to a coolant crossover tube (tested with the one on the front of my engine) and is located in the correct spot. Currently I only have a coolant crossover tube on the front of my engine that is connected to a radiator hose.
(testing coolant crossover tube on rear of engine below with hose connected)
2. I have a hose connection on the passenger side of my throttle body and I'm not sure what it connects to. Any idea? I've already connected all my radiator hoses and none go to it. Is this part of the AIR system?
The small hose connections ( 1/4" +-) on the throttle body are to allow coolant to circulate through the throttle body keeping it warm and guarding from potential icing. Many of us think this circulation is totally unnecessary and bypass the throttle body.
I added rear coolant air bleed lines and throttle body bypass over three years ago, no issues have come up.
https://www.westcoastcorvette.com/pr...17035218452526
That air line I believe that you have circled is for the HVAC (VAC Line) and is supposed to be connected to the back of the intake, see below pic of a LS6 Engine. Note as previously stated by other CF Members posting to this thread, the steam ports on the heads were blocked off on 2001 cars which you can see in the below pic.
That hose connection is to connect the throttle body via coolant line directly to the radiator, see pic below.
Cheers,
Goose
regarding the steam lines, the reason you don’t need them at the back of the heads is because the engine tilts downward ever so slightly, so the front crossover is your high point steam vent for the engine. If you bypass the line under the TB, the crossover still needs to connect to the radiator.
Connecting to the radiator gives you a steam (vapor) path back to the reservoir.
Finally, save yourself some grief later on getting air (vapor) out of the heads. Don’t overfill the reservoir. Never fill above the “full cold” mark. the mark is embossed on the front. Filling to the black top of the reservoir cold is too full. Filling too full will cause overheating sometimes mis-interpreted as steam bubbles in the heads.
In some respects, the reservoir acts like a DA tank on a boiler. the vapor space helps control boiling
