Delco CD Changer Install
Old Nov 21, 2002 | 10:41 PM
alans1's Avatar
alans1
Default Delco CD Changer Install
I received my CD Changer and $95 Delco CD install kit today. The install kit did not include: instructions, screws to mount the brackets to the changer or any fastners or epoxy to secure the body mounted bracket. Those of you that have performed this install, did I get cheated? :confused:
Old Nov 22, 2002 | 07:50 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Delco CD Changer Install (alans1)
Mine came with instructions (if you could call them that) and screws.
it does not come with epoxy or pop rivets, you must supply those. :cheers:
Old Nov 22, 2002 | 04:31 PM
KingTut's Avatar
KingTut
Default Re: Delco CD Changer Install (RPOZ4Z)
These are the 4 pages of instructions that come with it.
http://www.corvetteforum.net/c5/unxp...s/changer1.jpg http://www.corvetteforum.net/c5/unxp...s/changer2.jpg http://www.corvetteforum.net/c5/unxp...s/changer3.jpg http://www.corvetteforum.net/c5/unxp...s/changer4.jpg
There also were 6 screws for the brackets to the changer and 4 nuts to the body pannel. I also was provided 4 "rivets" but no way to use them.
I used golf club 2 part epoxy and a lot of it and that plate is not comming off. The only other hard part was finding the connectors under the floor board of the passenger side. Tip is to pull back the carpet and follow the existing cables. One connector is taped to the cable and the other is at the end of the cable that comes down along the front nearest the door.
Old Nov 22, 2002 | 09:32 PM
alans1's Avatar
alans1
I used 1/8" pop rivets and a 2 part 24 hour epoxy from Home Depot to secure the bracket. Thanks to everone who helped.
To Delco CD Changer Install
