electrical problem after jump start
Old Mar 25, 2020 | 03:23 PM
MaxOrbit's Avatar
MaxOrbit
Default electrical problem after jump start
Hello all, I'm posting this for a fellow club member with a 2002 Vette. His battery had died while in storage. He used his battery charger to jump start it which worked ok but now he has electrical problems. HIs power windows don't work, the traction control is on and won't turn off and some gauges don't work ( volt and oil pressure gauges). Fuse 29 in the BCM keeps blowing. He has it in the shop and they claim it's all caused by a faulty HVAC controller ( which I find hard to believe). He's looking for another good controller to try. Does anyone have any experience with this type of proble? The HVAC controller could cause the problem if it messes with the CAN bus.
Old Mar 25, 2020 | 04:17 PM
RichyB33's Avatar
RichyB33
I had to jump mine a week ago. After jumping it, the gauges didn't work at all. I ended up disconnecting the battery and reconnecting it. That seemed to clear up my problem. I don't know what it was, but it worked.
Old Mar 25, 2020 | 04:23 PM
JR-01's Avatar
JR-01
Shows once again not to jump start these cars with their delicate electronics. Charge a battery to 100%, install it and start your car.
Old Mar 25, 2020 | 04:53 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The electrical system is very sensitive. I always talk about not using a cheap battery tender, it could cause a lot of grief.
A dead battery should be charged outside of the electrical system.
Old Mar 25, 2020 | 08:33 PM
awches's Avatar
awches
Been using a Battery Tender Plus on my car for the last 3 yrs with no problems. But never jumped it even when I had a battery go bad last year.
Old Mar 25, 2020 | 11:56 PM
Moved to C5 Tech.
Old Mar 26, 2020 | 05:45 AM
Grandpa1's Avatar
Grandpa1
That's scary!
Old Mar 26, 2020 | 12:52 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Do you mean Fuse 29 at the IP Fuse Block ???...there are no fuses in the BCM physically. If it is indeed Fuse 29 it powers the lighter and the ALDL...that is Pin 16 at the DLC that powers it...if Fuse 29 were blown a scan tool would not be able to communicate with the cars modules and you will have all "No Comms" !!!... Now if the HVAC module loses either a power or a ground you may have issues on the CAN bus and with that issue you would also have all "No Comms" with a scan tool...you will see your power windows don't work, you will see all the DIC messages...R.E.P, low fuel, etc...and the gas gauge goes to E and the water temp gauge maxes out. The car may either not start or start and then stall. All your shop has to do is pull both splice pack bus bars near the BCM and probe all the pins with a scope...a good CAN bus signal is a 0-7 volt square wave...if they see either 12 volts or ground on any of those pins that is the bad module...easy to troubleshoot but you need the right diagnostic equipment.
Old Mar 26, 2020 | 03:12 PM
UM Rebel's Avatar
UM Rebel
Destroyed two Traction Control Modules jump starting. I learn kinda slow but I won't be doing that again.
To electrical problem after jump start
