Outside Temperature Reading Issue
Mar 28, 2020 | 07:05 PM
I just completed a mild restoration of my 2002 Corvette and have an issue with the outside temperature reading on the air conditioning display. I seems to show 69 degrees no matter what the outside temperature is. A/C and all display lights work fine. Any ideas? Thanks!
Mar 28, 2020 | 07:10 PM
Moderator, Tech Contributor
Make sure the harness connector is installed...if you disconnect it that is what you’ll see !!
Mar 28, 2020 | 07:13 PM
Where is the harness? I did drop the engine to replace all the seals. Is it the thing that plugs in on the front passenger side near the radiator?
Mar 29, 2020 | 09:59 AM
When I had this exact same problem it was the temperature sensor. It is on the front of the car on the passenger side. About a $28 part on eBay
https://www.ebay.com/itm/C5-C6-Corve...temCondition=3
Mar 29, 2020 | 10:45 AM
Thanks for the help and stay safe!
Mar 29, 2020 | 02:30 PM
Before you buy a new sensor, unplug the old one and clean the connector. They can get pretty grungy down there.
Mar 29, 2020 | 05:03 PM
I cleaned it and still no change. I just ordered a new AC Delco/GM one on Ebay for $9. Thanks again to everyone for the help and stay safe!
Mar 29, 2020 | 06:23 PM
Let’s hope it’s not a wiring issue...if it still doesn’t work after the sensor is replaced let us know !!
Mar 29, 2020 | 06:46 PM
Will do. Thanks again for all of the help!
