C5 Battery relocation - with pictures
How much smaller is the D51 battery?
D51 Yellow Top Length, 9.31 IN ; Width, 5.06 IN ; Height, 8.94 IN 26 lbs
It's a bit taller than the D35 but I'm putting it in a C5Z so I don't have a Lid on my compartment.
Using a Ballistic Fabrications battery box, it just Fits in the compartment. I'm goin to have to shim it up to fit over the unlevel floor. Haven't figured out how its going to mount up exactly let. I'll post pics once I get there.
- When I did the relocation, I used the center compartment for storage (ie: groceries/shopping/trips/etc.) so I really didn't want to lose the center.
- Eventually I plan to convert to a C6 style straight through exhaust, which means deleting the center storage.
- I wanted the full size battery because I didn't want to deal with the issues of limited cranking and storage capacity. I've had light weight/motorcycle batteries in vehicles before and it isn't worth the trouble to me.
- I was not interested in paying the price for a lithium battery. An Optima is expensive enough. I'm not racing, so I don't care about the added weight.
Thanks. I posted it because everyone talks about doing this mod, but either nobody ever does it or they don't bother to post anything on how they did it. I had to 100% wing it so this was my way.
Yes, it would be more centered in weight, but arguably most of the time I'm driving solo so I could also make an argument that having the battery on the right rear offsets the driver's weight on the left side. Does it matter? Probably not either way. In drag racing, everyone always put the battery in the right rear for traction (I'm not drag racing but just another point of where my perspective comes from).
- I've had it this way for several years now without any issues. Ultimately I'd still like to reinforce under the fiberglass with a metal tray, but I have yet to find time where life will allow me to invest into that project. Keep in mind, the C2 and C3 corvettes had their battery behind the driver's seat in a fiberglass well without any reinforcement and they are still out there working fine. *shrug*
https://dakotalithium.com/?gclid=Cjw...RoC2UIQAvD_BwE
I'm also not a fan of weight behind the axle (if you're not on a race track though, it really doesn't matter), but I am curious from a fab standpoint if you ever dropped that battery and added that aluminum you mentioned in the first post?
I don't want to do this install without using some kind of inline fuse at the battery.
Gary
