Check engine light
Old Apr 12, 2020 | 08:48 AM
Ramets's Avatar
Ramets
Default Check engine light
This has been driving me up the wall. I keep getting an intermittent check engine light. There doesn't seem to be any rhyme or reason to it. I did the simple remedy, I thought, by getting a new gas cap to no avail. I might go two weeks without the light coming on, then outta the blue it pops on again. I haven't been driving it much the past couple months, could that be part of the problem? Shouldn't there be a code popping up? If so I don't get one. Help!!
Old Apr 12, 2020 | 09:02 AM
69's Avatar
69
Cruise-In VI Veteran
I understand your frustration!!
When the CEL illuminates, did you pull the codes?
When you pull the codes, what are ALL the codes are posted to “current” or “history”…
Goose
Old Apr 12, 2020 | 10:49 AM
Ramets's Avatar
Ramets
Hey Goose, sorry it took so long to get back. Here's what I found. I have a P0440 code which I believe refers to the Evap. system. Since it's a relatively new gas cap, I don't believe that's the cause. The tank was pretty low when I filled it yesterday, so maybe that. I also in the past 6mos. put an oil catch can in. Could that be the culprit? I have other codes in the history, but the only current one is the P0440. A few in history are: B1543, B2282, and U1064.
Old Apr 12, 2020 | 12:03 PM
69's Avatar
69
Looks like you have an EVAP system leak somewhere....
Troubleshooting procedure for a 2003 model year car...I would focus on the EVAP lines on the top of the engine along the intake manifold...
DTC P0440
System Description
The control module tests the evaporative emission (EVAP) system for a large leak. The control module monitors the fuel tank pressure (FTP) sensor signal to determine the EVAP system vacuum level. When the conditions for running are met, the control module commands the EVAP canister purge valve OPEN and the EVAP vent valve CLOSED . This allows engine vacuum to enter the EVAP system. At a calibrated time, or vacuum level, the control module commands the EVAP canister purge valve closed, sealing the system, and monitors the FTP sensor input in order to determine the EVAP system vacuum level. If the system is unable to achieve the calibrated vacuum level, or the vacuum level decreases too rapidly, this DTC sets.
The following table illustrates the relationship between the ON and OFF states, and the OPEN or CLOSED states of the EVAP canister purge and vent valves.
Conditions
Conditions for Running the DTC
• DTCs P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0125, P0443, P0449, P0452, P0453, P1112, P1114, P1115, P1120, P1133, P1134, P1153, P1154, P1220, or P1221 are not set.
• The ignition voltage is between 10-18 volts.
• The barometric pressure is more than 75 kPa.
• The fuel level is between 15-85 percent.
• The engine coolant temperature (ECT) is between 4-30°C (39-86°F).
• The intake air temperature (IAT) is between 4-30°C (39-86°F).
• The start up ECT and IAT are within 9°C (16°F) of each other.
• The vehicle speed sensor (VSS) is less than 121 km/h (75 mph).
Conditions For Setting the DTC
The EVAP system is not able to achieve or maintain vacuum during the diagnostic test.
Action Taken When the DTC Sets
• The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
• To help locate intermittent leaks, use the J 41413-200 Evaporative Emissions System Tester (EEST) to introduce smoke into the EVAP system. Move all EVAP components while observing smoke with the J 41413-SPT High Intensity White Light.
• A temporary blockage in the EVAP purge solenoid, purge pipe or EVAP canister could cause an intermittent condition. Inspect and repair any restriction in the EVAP system.
• To improve the visibility of the smoke exiting the EVAP system, observe the suspected leak area from different angles with the J 41413-SPT .
• Reviewing the Failure Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
• For intermittent conditions refer to Intermittent Conditions .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
2. This step verifies that a failure condition is active.
4. Introducing smoke in 15 second intervals may allow smaller leak areas to be more noticeable. When the system is less pressurized, the smoke will sometimes escape in a more condensed manner.
6. This step verifies proper operation of the FTP sensor.
7. A normal operating FTP sensor should increase above 5 inches of H2O and Stop between 6 inches of H2O and 7 inches of H2O.
9. This step tests the EVAP purge solenoid vacuum source between the EVAP purge solenoid and the Intake manifold for restrictions or blockages.
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
1. Observe the Freeze Frame/Failure Records for this DTC. 2. Perform the Service Bay Test. Refer to Service Bay Test .
Does the scan tool indicate that the Service Bay Test passed?
Go to Diagnostic Aids Go to Step 3
3
1. Inspect the evaporative emission (EVAP) system for the following conditions:
2. Raise the vehicle on a hoist. Refer to Lifting and Jacking the Vehicle in General Information. 3. Inspect the EVAP system for the following conditions:
Did you find and correct the condition?
• Loose, missing, or damaged service port schrader valve
• Loose, incorrect, missing, or damaged fuel fill cap
• A damaged EVAP purge solenoid.
• Disconnected, improperly routed, kinked, or damaged EVAP pipes and hoses
• A damaged EVAP vent solenoid or EVAP canister
Go to Step 19 Go to Step 4
Important: Ensure that the vehicle underbody temperature is similar to the ambient temperature and allow the surrounding air to stabilize before starting the diagnostic procedure. The system flow will be less with higher temperatures.
1. Turn OFF the ignition. 2. Connect the J 41413-200 Evaporative Emissions System Tester (EEST) power supply clips to a known good 12-volt source. 3. Install the J 41415-40 Fuel Tank Cap Adapter to the fuel fill pipe. 4. Install the fuel fill cap to the J 41415-40 5. Connect the J 41413-200 nitrogen/smoke supply hose to the J 41415-40 . 6. Turn ON the ignition with the engine OFF.
4
7. Command the EVAP vent solenoid closed with a scan tool. 8. Turn the nitrogen/smoke valve on the J 41413-200 control panel to SMOKE. 9. Use the remote switch to introduce smoke into the EVAP system. 10. Use the J 41413-VLV EVAP Service Port Vent Fitting to open the EVAP service port. 11. Remove the J 41413-VLV once smoke is observed. 12. Continue to introduce smoke into the EVAP system for an additional 60 seconds. 13. Inspect the entire EVAP system for exiting smoke with the J 41413-SPT High Intensity White Light. 14. Continue to introduce smoke at 15 second intervals until the leak source has been located.
Did you locate and repair a leak source?
Go to Step 19 Go to Step 5
5
1. Disconnect the J 41415-40 from the fuel fill pipe. 2. Install the fuel fill cap to the fuel fill pipe. 3. Connect the J 41413-200 nitrogen/smoke supply hose to the EVAP service port. 4. Use the remote switch to introduce smoke into the EVAP system. 5. Inspect the entire EVAP system for exiting smoke with the J 41413-SPT . 6. Continue to introduce smoke at 15 second intervals until the leak source has been located.
Did you locate and repair a leak source? 7
1. Seal the EVAP system using the EVAP Purge/Seal function with a scan tool. 2. Turn the nitrogen/smoke valve on the J 41413-200 control panel to NITROGEN. 3. Use the J 41413-200 to pressurize the EVAP system to the first specified value.
Is the Fuel Tank Pressure sensor parameter more than the second specified value?
10 in H2O
5 in H2O
Go to Step 8 Go to Step 16
8
1. Use the remote switch to stop introducing nitrogen into the EVAP system. 2. Increase the EVAP purge solenoid to 100 percent.
Is the Fuel Tank Pressure parameter less than the specified value?
1 in H2O
Go to Diagnostic Aids Go to Step 9
9
Disconnect the EVAP purge vacuum source from the EVAP purge solenoid.
1 in H2O
Go to Step 13 Go to Step 10
10
Disconnect the EVAP purge pipe from the EVAP purge solenoid.
1 in H2O
Go to Step 17 Go to Step 11
11
Disconnect the EVAP purge pipe at the EVAP canister.
1 in H2O
Go to Step 15 Go to Step 12
12
Disconnect the EVAP vapor pipe at the EVAP canister.
1 in H2O
Go to Step 18 Go to Step 14
13
Repair the pinched or obstructed EVAP purge solenoid vacuum source
Did you complete the repair?
Go to Step 19 --
14
Repair the pinched or obstructed EVAP vapor pipe.
Go to Step 19 --
15
Repair the restriction in the EVAP purge pipe. Refer to Evaporative Emission System Hoses/Pipes Replacement .
Go to Step 19 --
16
Replace the FTP sensor. Refer to Fuel Tank Pressure Sensor Replacement .
Did you complete the replacement?
Go to Step 19 --
17
Replace the EVAP purge solenoid. Refer to Evaporative Emission Canister Purge Solenoid Valve Replacement .
Go to Step 19 --
18
Replace the EVAP canister. Refer to Evaporative Emission Canister Replacement .
Go to Step 19 --
19
Go to Step 20 Go to Step 3
20
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List System OK
Go to Step 19 Go to Step 6
6
1. Use the remote switch to stop introducing smoke. 2. Install the J 41415-40 to the fuel fill pipe. 3. Connect the J 41413-200 nitrogen/smoke supply hose and vehicle fuel fill cap to the J 41415-40 . 4. Command the EVAP vent solenoid open with a scan tool. 5. Compare the Fuel Tank Pressure (FTP) parameter with a scan tool to the J 41413-200 pressure/vacuum gage.
Is the scan tool Fuel Tank Pressure parameter within the specified value of the J 41413-200 pressure/vacuum gage?
1 in H2O
Go to Step 7 Go to Step 16
Old Apr 12, 2020 | 12:08 PM
Ramets's Avatar
Ramets
If not taken care of right away can any harm be done to the engine??
Old Apr 12, 2020 | 12:43 PM
69's Avatar
69
The fault code indicates the fuel tank is open to atmosphere therefore you may smell gas if you park your car in a garage (at your house) similar to leaving the top off of a gas can…
AS the car is not posting a LEAN engine code, I would believe that the risk to your engine is low but when the car runs the test, It’s like a vacuum leak on the engine and you may feel some engine roughness while the test is running.
NOTE> EVAP TESTING Smoke machine. If you search the interwebs on “how to make a EVAP Smoke Machine you will see many cheep options on this how-to…Or you can buy this machine fairly cheep if you decide to fix the car yourself…
You have options.
Cheers,
Goose
Old Apr 12, 2020 | 12:47 PM
Ramets's Avatar
Ramets
Thanks for the help. It's very much appreciated!!!!
To Check engine light
