Dic.
Old Dec 6, 2018 | 04:51 PM
wldvette98's Avatar
wldvette98
1st Gear
Default Dic.
98 C5 DIC is no working, any one know how to fix
Old Dec 7, 2018 | 02:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is the display dead???? You can disassemble the IPC and re seat all the plug in stuff.. Sometimes that gets it working again. Carefully inspect the mother board for damage and also look at the main IPC connector where it connects to the board. Look for cold solder joints and or corrosion.
Bill
Old Apr 6, 2020 | 11:37 PM
LittleRiverBK's Avatar
LittleRiverBK
Cruising
My DIC issue is the Chevy Corvette logo lights up initially, then the odometer shows briefly...then the DIC goes blank. All the other instrument cluster parts work normally.
All the fuses connections check out fine. The plan is to check the IPC, then replace the ignition switch.
Bill, do you agree with this approach?
Old Apr 7, 2020 | 02:09 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% YEP!! Recommend that you connect a DC Volt Meter to the IPC Fuse test points and read the voltage during turn on. When the IPC FAULTS, that voltage may show LOW.. YES,,,, That would point to a faulty Ignition switch..
Old Apr 12, 2020 | 12:05 AM
LittleRiverBK
Cruising
Thanks Bill. Will let you know.
Old Apr 12, 2020 | 03:38 PM
OregonDan's Avatar
OregonDan
And if it turns out that you need an ignition switch, I just happen to have one! Complete with bracket and one cut key, one uncut key.
To Dic.
