tires
Old Apr 20, 2020 | 06:43 AM
Joe Scafide's Avatar
Joe Scafide
Default tires
is it me I noticed my gas millage is better since I took run crap tires off and went with non runflats mitch piolet sport is it because of weight?
Old Apr 20, 2020 | 08:09 AM
Gordy M's Avatar
Gordy M
When I ran my runflats, first 15000 miles, I received better gas mileage on trips than afterwords. More than likely you current set is well worn and aged, unless it is a daily driver. The sidewalls of runflats are very rigid and that usually leads to better mileage at the cost of handling.
Old Apr 20, 2020 | 04:42 PM
Hitman227's Avatar
Hitman227
Prolly not from the tires, unless they are excessively bad causing more rolling resistance
Old Apr 21, 2020 | 06:09 AM
Joe Scafide
Default Tires
I think runflats weigh more less weight better gas milage?
Old Apr 21, 2020 | 08:25 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
In that respect, I would tend to think that MAYBE, when starting from a dead stop, the heavier RFs might require a bit more energy, in order to get the car in motion, but once rolling, their stiffer sidewalls would offer less rolling resistance. And most likely, those two factors would cancel each other out.
Old Apr 21, 2020 | 07:44 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I think with your new tires, you are driving easier and smoother, not like an animal, therefore saving fuel.
Old Apr 22, 2020 | 09:31 AM
Joe Scafide
Default Tires
R u kidding with streets empty i tend to drive more aggressive
Old Apr 22, 2020 | 08:28 PM
redzg's Avatar
redzg
Any chance the tire pressure is toward the high end of the warning range vs the old tires being at the low end?
Old Apr 24, 2020 | 05:46 AM
Joe Scafide
Default Tires
ran 30#s cold just the old piolet sports were 11years old ? But i only drove when cold out with no air on but the ride is much with none runflats
To tires
