Coilovers uneven?
Old Apr 21, 2020 | 02:33 PM
jrp1588's Avatar
jrp1588
Default Coilovers uneven?
I installed some Aldan coilovers in the rear over the weekend. When I got everything buttoned up, put a half inch preload on them, and measured both to confirm I had them set the same, I put the car on the ground, and the passenger side was probably a bit over .25" or so lower than the driver. I had to adjust the one side up a fair bit to get it to match, even after a bit of spirited driving to get things to settle in. Is this to be expected, or is there something I'm missing that I should look at?
Old Apr 21, 2020 | 06:55 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
just adjust to level, all corners will not always be the same !!
Old Apr 21, 2020 | 08:59 PM
Hitman227's Avatar
Hitman227
Yes, on my Firebird I installed 1le springs that are supposed to be in spec, and they were off by a little amount..
Also make sure they are fully settled with driving so you are getting a good reading.
Old Apr 21, 2020 | 09:14 PM
jrp1588's Avatar
jrp1588
Good to hear. Guess I'll take it for a few more rips and see how she settles. Rides pretty nice anyway. Don't really know how to describe it, but it definitely feels different.
Old Apr 26, 2020 | 11:20 PM
Hitman227's Avatar
Hitman227
That's nice, good to hear, they most likely are much stiffer overall, handle very good..
Old Apr 27, 2020 | 09:38 AM
jrp1588's Avatar
jrp1588
Bit of a mixed bag. Bigger bumps are now pretty rough. I feel like it follows smaller bumps better without wanting to jump all over the place though. With the quarantine, I haven't really had much reason to go out driving, so I don't have much time on them. Rear end grip feels a lot more confident when I'm accelerating hard, but I've also fixed the rear tie rod ends when I was in there, which was making the rear end real loosey-goosey.
To Coilovers uneven?
