SDM - NO COMM message
Old Apr 24, 2020 | 10:58 AM
mompantero's Avatar
mompantero
Default SDM - NO COMM message
My 98 C5 is posting a message on the DIC that states "SDM-NO COMM" so I guess the SD module is not communicating with the IPC. I recently changed the IPC to new - used one and transferred the odometer chip but have not gotten the original VIN programmed in. A GM Master Tech told me that the VIN mismatch would not cause this problem, it's either a power issue or failure in the COMM link to the IPC. To the best of my knowledge the car has not been crashed and there are no crash issues reported on CARFAX. I checked out the issue in the SM but it does not address this message. I checked for the dumb stuff like blown fuses and disconnected wires under the seat, all is OK there. Has anyone encountered this one before?
Old Apr 24, 2020 | 11:30 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
For any module “no comm” the first thing to check are the modules power and ground !!
Old Apr 24, 2020 | 03:39 PM
mompantero's Avatar
mompantero
Thanks, trying to figure out how to do that without tearing half the car apart to get to the SDM. Service Manual is not super-clear on location of the connectors outside the console where the SDM lives. I'll continue to study the SM and find a good spot for a power and ground check. Car is rarely driven so I'm not in a rush.
Old Apr 24, 2020 | 04:10 PM
C5 Diag's Avatar
C5 Diag
Looks like you’ll just have to remove the Accessory Trim Plate and the HVAC control head...should be below the HVAC...connector is in the front !!...it’s best to check power and ground at the module itself....do you have any U” codes (communication codes) present ??
Old Apr 24, 2020 | 05:24 PM
mompantero's Avatar
mompantero
As usual, I just had the trim panels out to replace the IPC. Was hoping I could do this elsewhere, i.e. without taking it apart again, this will be number 4 in the last month (the fault didn't show up till after I replaced the IPC!! I appreciate the advice, at present I have the intake off to replace knock sensors and the knock sensor harness. There are no U codes, only and air bag light and an SDM - NO COMM on the DTC. When the knock sensors are wrapped up I'll pull out the trim and take a shot at it. Like most "things Corvette", you can be sure it will be the most expensive fix possible, e.g. SDM is shot. Thanks for the advice, I appreciate the help from you guys that know these cars much better than I ever will.
Old Apr 24, 2020 | 05:38 PM
C5 Diag's Avatar
C5 Diag
Since this happened after replacing the IPC go back in and see if anything was disturbed like the harness connector...good luck !!
Old Apr 24, 2020 | 06:58 PM
mompantero's Avatar
mompantero
Will do, good suggestion.
Old Apr 25, 2020 | 08:34 AM
mompantero's Avatar
mompantero
One other question. I can't find out whether the SDM is specific to a VIN; i.e. if the IPC is swapped and the original VIN has not been re-programmed could this cause the module to loose communication? I can't find any info in the service manual about VIN programming issues.
Old May 15, 2020 | 09:57 PM
mompantero's Avatar
mompantero
FINAL POST - After a lot of fooling around with grounds, power supply and checking connectors with no faults I became convinced the problem was the SDM itself. I found a replacement with the identical part and service number. I installed it and the computer picked it up right away. the light is out and all is well. I really suspected the SDM right out of the bat but was reluctant to change it because of the need to re-program, Found out that the VIN is not in the SDM, What is checked in the state of health test that it does when the car is turned on is to look for the last 4 digits of the part number. If it's the same communication is established. So my problem is fixed without any costly outside "help".
Old Jun 24, 2024 | 11:09 PM
Joesconvert98's Avatar
Joesconvert98
Cruising
Default Same issues old post question
I have this problem as well. Mine does the usual 7 flashes and the airbag light is on and then turns off after the 7 flashes.
To SDM - NO COMM message
