2001 Steering Wheel Sensor C1287
Old Apr 26, 2020 | 12:37 AM
hippy's Avatar
hippy
Default 2001 Steering Wheel Sensor C1287
So, this has probably been beaten to hell already and since I've searched for this particular question and found no answer I am going to ask it. I am getting a C1287 code. I pulled the plug and installed 3 jumpers wires to check voltage when hooked up to the sensor. With the steering wheel centered should I get 2.5v off of both the green and blue wire at the same time? I am getting 2.5v off the green wire but only 9.6mv off the blue wire. When I turn the wheel 90 degrees I get the blue wire to go to 2.5v. and a decrease in the green wire. So is this an indication of a bad sensor?
