Just installed LS6 intake, Idle going nuts
Old Nov 23, 2002 | 08:30 PM
jlamay's Avatar
jlamay
Default Just installed LS6 intake, Idle going nuts
The car either idles at 2200, or it idles at 600, and jumps between 600-900 and feels like its going to stall. Any suggestions? I also installed new plugs, NGK TR-6 (gapped at 55) and new taylor wires. I'm pretty sure I reattached everything.
[Modified by jlamay, 5:41 PM 11/23/2002]
Old Nov 23, 2002 | 09:04 PM
Patches's Avatar
Patches
Default Re: Just installed LS6 intake, Idle going nuts (jlamay)
Do an idle relearn.
Also, aren't those colder plugs supposed to be gapped at around .038"?
:cheers:
Idle Relearn Procedure
Automatic Transmission:
1 Turn off the ignition
2 Restore the PCM battery feed
3 Turn Off the AC controls
4 Set the parking brake and block the drive wheels
5 Start the engine
6 Allow the engine coolant temperature to reach 176 degrees F
7 Shift the transmission selector into the drive range
8 Allow the engine to idle for 5 minutes
9 Turn on the AC controls (Omit for 2000-01 model)
10 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
11 Shift the transmission selector into Park
12 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
13 Turn off the AC controls (Omit for 2000-01 model)
14 Allow the engine to idle for 5 minutes
15 Turn off the engine for 15 seconds
Manual Transmission:
1 Turn Off the ignition
5 Transmission in neutral
6 Start the engine
7 Allow the engine coolant temperature to reach 176 degrees F
8 Turn on the AC controls (Omit for 2000-01 model)
9 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
10 Turn off the AC controls (Omit for 2000-01 model)
11 Allow the engine to idle for 5 minutes
12 Turn off the engine for 15 seconds
[Modified by Patches, 9:34 PM 11/23/2002]
Old Nov 23, 2002 | 11:01 PM
chuckster's Avatar
chuckster
SOunds like a vacuum leak..
Did you remember to connect that little tiny vacuum line on the rear of the intake..If you did not the A/C controls wont work either..
Old Nov 23, 2002 | 11:40 PM
jlamay's Avatar
jlamay
Default Re: Just installed LS6 intake, Idle going nuts (chuckster)
Chuckster - Yes, I did (unless the stupid thing came loose). I'm doing the idle relearn and it seems to help.
Patches - "Also, aren't those colder plugs supposed to be gapped at around .038"? "
where did you see the info on the TR-6 and gapping? If that is the case I'll have to pop them out and regap them.
Old Nov 24, 2002 | 12:29 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Why are you running the TR-6's. are you running the car N/A ?
Old Nov 24, 2002 | 01:33 AM
jlamay's Avatar
jlamay
Default Re: Just installed LS6 intake, Idle going nuts (CHRIS NJ C5)
By N/A I'm assuming you mean Naturaly Aspiriated? If that's what it means, then yes, no turbo, super or any other type of charger. See my sig for the mods.
Old Nov 24, 2002 | 07:07 AM
Patches's Avatar
Patches
If you're running N/A, you should be using the TR55's as the TR6's are better suited for FI and nitrous applications. :cheers:
To Just installed LS6 intake, Idle going nuts
