* Heads/cam/pulley install writeup done *
The writeup has detailed instructions that most people that can turn a wrench can follow, and during the heads/cam install there are optional instructions to install a new oil pump, a new timing chain, a new intake manifold, or an underdrive pulley, however those parts are not required. The torque specs are pulled from the GM manuals.
Note, the writeups with the C5 logo next to them apply to the C5 cars. The ones with "fbody" next to them are of course, for fbodies (I have an ls1 fbody and a C5).
My webpage URL is: http://www.ls1howto.com/
Some interesting stats...
- The C5 writeup with all pictures, is 8.1megabytes
- There are over 50 images used in the C5 writeup
- When printed, the c5 writeup is between 22 and 29 pages long
- The information was collected over the process of 3 C5 head installs I worked on, as well as 6 fbody head swaps and 10 cam swaps total (2 ybody, 8 fbody)
NOTE: The page is a living page, and I update it every time somebody emails me with corrections or suggestions, so DON'T print pages out until the day of your install or you may miss important updates.
[Modified by jmX, 9:22 AM 11/24/2002]
Excellent write up, stuff like that takes time and its appreciated :thumbs:
[edit] oops, reread it and you answered my question on the abs/ah pump - need more coffee :)
[Modified by kp, 11:56 AM 11/24/2002]
:cheers:
[Modified by jfpilla, 7:04 PM 11/24/2002]
(for those of you who dont know, I've recently learned the diff the hard way :D )
Thanks everybody for the feedback, spread the word and feel free to tell people about the site. It can only be made better if people actually use it! Don't be scared away by the length, I typed in as much detail so it ended up looking like a HUUUUUGE task when its not that big of a deal.
I have one question, I do have a extra Tapping Noise inside the car. When I give the gas that is when it occurs and when the clutch is pressed in the sound quits for a second. I am going back to the performance shop to get some info.
I hope it is not normal like you mentioned.
