Brakes Locking Up
Old May 15, 2020 | 10:45 PM
Will23's Avatar
Will23
Cruising
Default Brakes Locking Up
Brakes locking up
I have a 01 Corvette z06 and having issues with the brakes wanting to lock up. This issue began to occur after replacing my ebcm which had an internal code that couldn’t be repaired. When I get up to about 10 mph it begins to occur and the traction control symbol comes on in the dash. I ended up unplugging the ebcm connector and was able to drive it without any issues other than the abs and traction control symbols appearing on the dash. Has anyone had this issue before or any idea as to what might be going on.
Old May 16, 2020 | 09:08 AM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
When my wheel speed sensor wire broke on the front right wheel, that wheel would lock up under hard braking. Not all the wheels. Do all your wheels lock up?
Old May 16, 2020 | 06:38 PM
Will23's Avatar
Will23
Cruising
It feels like all of them and the brake pedal is hard.
Old May 17, 2020 | 11:04 PM
Moved to C5 Tech.
To Brakes Locking Up
