17x11 wheels
Old Nov 25, 2002 | 01:24 AM
gojo's Avatar
gojo
Default 17x11 wheels
Other than sticking out from the rear fender a little, is there any reason not to use the ZR1 17x11's with the 36mm offset, on a C5?
Old Nov 25, 2002 | 03:55 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: 17x11 wheels (jfpilla)
Exactly what does the off set mean, because mine are 50mm off set and they only stick out a little. I guess that is how far they stick out. So 14 mm would be just a little more than 1/2 an inch, therefore, they might not stick out at all or just slightly. If that is the case, I see no problem unless the wheel hits the A frame arm, then you will need to grind it slightly. See the Pic.
[Modified by wallstAL, 1:05 AM 11/25/2002]
Old Nov 25, 2002 | 08:29 AM
Jim 47's Avatar
Jim 47
Default Re: 17x11 wheels (wallstAL)
Wheel Offset is the distance from its hub mounting surface to the centerline of the wheel.
The offset is Positive if the mounting surface is toward the front side of the wheel, and Negative if the mounting surface is toward the back side of the wheel. On the ZR1 wheels, the offset is Positive, so a 36 mm offset will stick out further than a 50 mm offset wheel. :cool:
Old Nov 25, 2002 | 09:41 AM
6Speeder's Avatar
6Speeder
Default Re: 17x11 wheels (Jim 47)
I run the 50mm offset 17 x 11 wheels on the street, they do stick out a bit, not much. They don't rub, even with my 335/35ZR 17 tires. :cool:
Old Nov 25, 2002 | 01:05 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
MY GS wheels must have a negative 50mm offset, if they had a positive offset they would stick out much farther than a positive 35mm offset. Is that correct!
Old Nov 25, 2002 | 01:16 PM
Jim 47's Avatar
Jim 47
Your GS wheels have a 50mm Positive offset. Make youself a little diagram and you will see that a 36mm ZR1 wheel will stick out further than a 50mm GS wheel. :cool:
Old Nov 25, 2002 | 02:26 PM
gojo's Avatar
gojo
Good information guys. Thanks for the picture Al. The 36mm will stick out 1/2" more than yours do. I would not mind that at all for the track.
Old Nov 25, 2002 | 03:27 PM
Red5's Avatar
Red5
you really should go with the gs offset. The 36 will stick out too far in the rear and Can't be used in the front. They will rub.
Old Nov 25, 2002 | 04:35 PM
sacsrpc's Avatar
sacsrpc
Default Re: 17x11 wheels (Red5)
wallst,,did you find a good deal on mobil1?? looks like your garage is stocked! :cheers:
Old Nov 25, 2002 | 04:54 PM
gojo's Avatar
gojo
I will go with the GS offset. GS wheels, rear only, would look good at the drags. Pricey aren't they?
Old Nov 25, 2002 | 08:33 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: 17x11 wheels (sacsrpc)
I think I paid $22 a case at Costcos, my 2 daughters always ask me to change their oil, so I just keep a good supply.
Old Nov 26, 2002 | 02:06 AM
bparker's Avatar
bparker
Go with the GS Wheels - and here is a link that will save you some $
http://www.afswheels.com/corvette_wheels/index.asp
:cheers:
To 17x11 wheels
