99 Corvette
Old May 19, 2020 | 09:38 PM
Firemateo's Avatar
Firemateo
3rd Gear
Default 99 Corvette
Hello,
I have a 99 corvette with 46k. It recently started making a squealing noise. Sounded like a belt. I changed out the idler pulley, tension pulley and the serpentine belt. Noise is still there. I have researched it and sounds like it may be the harmonic balancer. Wondering if anyone here has had any experience with this or had the same issues and what the fix was, before I go replacing unnecessary parts.
Thank you in advance
Old May 20, 2020 | 05:18 AM
Moved to C5 Tech.
Old May 20, 2020 | 08:07 AM
kingfurook's Avatar
kingfurook
Just did mine. These two threads should help you out.
​​​​​​https://www.corvetteforum.com/forums...post1601527078
https://www.corvetteforum.com/forums...post1601522988
Old May 20, 2020 | 10:10 AM
JWM's Avatar
JWM
Not sure why the harmonic balancer would make a squealing noise but at 21 years of age, it is probably due for replacement. The original on my '98 recently failed at 44K
Old May 20, 2020 | 08:00 PM
Firemateo's Avatar
Firemateo
3rd Gear
Replacing the harmonic balancer is a task hoping it is it. Hate to replace that and not fix the problem
Old May 21, 2020 | 09:32 PM
slo-ryd's Avatar
slo-ryd
Default 99 Corvette
Have you taken the belts off and started it to see if it still squeals?
Old May 21, 2020 | 10:46 PM
Firemateo's Avatar
Firemateo
3rd Gear
I have not tried taking the belts off and running it. Not overly mechanically inclined. I can figure most things out on my own but this ones bugging me. Will that harm the car in any way running it like that? Along with if it still squeals what would that pose the issue would be?
To 99 Corvette
