You hit the remote button twice to get the passenger door to unlock. And I think, if you turn the drivers key twice in the drivers door lock, it will unlock the passenger door.
Relay in the door control module. Buy a new one for five bucks and solder it in from digilink.
What kind of relay? I've got the same issue, but just ordered a replacement module a while ago. If it's repairable, I'd rather just fix it and then sell one.
From: Smithtown New York/Naples Florida/Flint Twp. Michigan
I did mine about 10 years ago. First you should check to make sure that the power is going in but not out of the door module relay. Just look at the schematic and probe the correct wires. I had to remove the circuit board from the module and unsolder the relay from the board. I bought the relay from Digikey. I can't remember wether I used the numbers off the relay or got the part number from the Forum thread but Digikey will help you select the right one if you call them. It's a pretty simple repair. Check for a thread on the Forum for the fix.
Reason: Wrong name of supplier
