Driver side door not unlocking
Old Nov 25, 2002 | 12:51 PM
-Y-'s Avatar
-Y-
Default Driver side door not unlocking
Noticed last week that the drivers side door doesn't always unlock when unlocking the doors with the key fob (passenger side did unlock so I know I pushed the button), and the last 2 days it hasn't unlocked when I remove the key from the ignition (passenger side does unlock). Has anyone seen this happen?
Old Nov 25, 2002 | 12:53 PM
skidmarc's Avatar
skidmarc
Default Re: Driver side door not unlocking (dby)
yes this happened on my 2000....they replaced the relay in the door a few times...
Old Nov 25, 2002 | 01:03 PM
-Y-'s Avatar
-Y-
Default Re: Driver side door not unlocking (skidmarc)
Thanks for the info!!
Old Nov 25, 2002 | 01:22 PM
SoCal C5's Avatar
SoCal C5
Sometimes the problem is the door control module mounted behinde the door handle (usually just a bad relay, but the relays are soldered in so the whole thing needs to be replaced) or the lock accuator (the electro/mechanical part that physically locks/unlocks the door). It think the module is the most common cause though.
Old Nov 25, 2002 | 01:59 PM
SteveL2's Avatar
SteveL2
I'm with the others. I have had the module switch replaced on both of the doors in my '01 coupe. Good luck. :seeya
[Modified by SteveL2, 1:00 PM 11/25/2002]
Old Nov 25, 2002 | 02:09 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
As has already been said, replace the door control module. Mine does the same thing, I just haven't gotten around to fixing it.
Old Nov 25, 2002 | 05:20 PM
BLKBLUR's Avatar
BLKBLUR
Yup, mine started last month on my '02. I haven't had time to take to the dealer since we moved. I hope to get it in before the holidays, but it may have to wait until after New Years.
Good to here what it is--hopefully the dealer will know too. Thanks guys :thumbs:
Old Nov 25, 2002 | 05:48 PM
etekberg's Avatar
etekberg
Me too! Mine does the same thing. Amazing how the pretty much all of the problems with these cars are common.
Old Nov 25, 2002 | 09:32 PM
-Y-'s Avatar
-Y-
As I should have expected... the door unlocked just fine when I was leaving work and when I got home. I hate intermittent problems.
To Driver side door not unlocking
