C5 fuel cutoff
Old May 26, 2020 | 11:03 PM
DeeLaja's Avatar
DeeLaja
Default C5 fuel cutoff
I had my c5 tuned to 255 mph fuel cut off due to service column lock but car now cutting off at 10-20 mph when I accelerate do you guys know if anything ones done wrong I deactivated my security lock system too my tuner did it all
Old May 26, 2020 | 11:50 PM
Moved to C5 Tech.
Old May 27, 2020 | 01:35 AM
jim993's Avatar
jim993
You should go back to the shop that set the fuel cutoff and explain the symptoms. Hopefully they can fix it.
If not, check codes and report back
Old May 27, 2020 | 06:53 AM
DeeLaja's Avatar
DeeLaja
Default Yea jack he checked my car on hp tuners when he hit the gas my fuel numbers
yea jack when he hit the gas my fuel numbers our low on hp tuners he said it could be the fuel filter
To C5 fuel cutoff
