C5 automatic transmission issues
Old May 27, 2020 | 05:07 PM
Chad Bergeron's Avatar
Chad Bergeron
Default C5 automatic transmission issues
My c5 has, over the last couple weeks, not been shifting properly. When I start from a stop or even slow speeds, it revs way high and wont shift into 2nd for a while even with barely pressing the gas. And when it does finally shift, it immediately shift into 3rd. It's very consistent with that issue. Not getting any codes either.
Another similar issue is if I'm already going around 75mph and then gun it, it's used to go immediately. Now it revs and feels like it's about to catch and take off but then often times it doesnt and it just revs really high and I have to take foot off the gas. A friend of mine mentioned something about "friction material" could be wearing out?? I dont know anything about transmissions so I'm trying to find as much info as I can before I spend money on even a proper diagnostic fee. Does this sound like a simple-ish/cheap-ish issue to resolve or no?
Old May 27, 2020 | 05:17 PM
Will_M1911's Avatar
Will_M1911
Sounds like it could be your Throttle Position Sensor.
https://twincharlotte.com/30-common-...-charlotte-nc/
Old May 30, 2020 | 01:19 PM
ncali's Avatar
ncali
it sounds like you have burnt clutches in the trans. check the trans oil temp when it slips and see if it is much higher
Old May 30, 2020 | 10:08 PM
lionelhutz's Avatar
lionelhutz
I agree, sounds like a clutch pack is slipping. Check it for burnt fluid.
Old Jun 2, 2020 | 07:43 PM
Chad Bergeron
ok thanks for the replys, im hoping its like the first guy said and its the TPS. i was driving around today and got these 4 codes ill add with a link to the pages describing the issues. if anyone would be able to make a better educated guess and see if it sounds more like the TPS now, that would be great. thanks in advance.
https://www.engine-codes.com/p1120.html
https://www.engine-codes.com/p1220.html
https://www.engine-codes.com/p1514_chevrolet.html
https://www.engine-codes.com/p1516_chevrolet.html
To C5 automatic transmission issues
