C5Z Throwout Bearing!? I think??
less than 500 miles on new clutch, TOB, MC, rebuilt diff. Did the work myself, very meticulous, every wire, nut, bolt, clip, etc
Horrible grinding noise when in Neutral and clutch OUT (released)
Clutch IN (pressed) - no noise!
No noise in any gear!
It just started doing this sitting in my garage warming up! 60 seconds into warming up, just sitting in Neutral, clutch released, started making horrible grinding noise. I killed the engine in a hurry let me tell you.
Check the video - tell me what you think. Bled the hydraulics, looks fine, no change.
TOB, correct? not the pilot bearing, it's spinning when clutch is IN (disengaged) and the engine is spinning around the stationary output shaft.
By the numbers.
Free lash/distance between the pressure plate fingers to the back of the bell housing, .124" to 1.50" greater than the distance of the face of the TB bearing (pushed all the way down against the outer spring on the slave), to the face of the torque tube? Hence do not have the TB pre loaded against the pressure plate fingers instead.
Pilot bearing in the flywheel good and the correct size for the front of the torque tube shaft nose (read shaft nose area not all marred to hell, or under size spun worn isntead to cause the torque tube shaft to be loose in the pilot bearing.
Lastly, if you have a tick master cylinder installed, make sure that you have the free lash adjusted correctly. The tick master cylinder can over drive the TB if not adjusted with free play correctly, and force the TB on race to far forward inward against the pressure plate fingers.
So my guess, either free play problem between TB and pressure finger too short and the TB was pre loading all all time to take it out quickly (or just melt is way down on the plastic TB race that is now scrapping off the fingers), the input shaft end of the torque tube was trash or forward loaded on the bearing, which could have been caused by the flywheel not heated and fully seated on the crank surface to start with. Hence the reason that you always check the free gap before you install the drive line to the bell housing.
https://www.corvetteforum.com/forums...uestion-2.html
All of that isn’t rotating with the clutch in. The pilot bearing is probably destroyed (needles all over within the race) due to the torque tube bearing allowing excessive input shaft side load/walk.
This is an RPS MAMO BC2 clutch, low mile used from another member. Any clearance issues with bolts to the clutch would’ve been immediate, not just happen in my garage one day.
Input shaft look great, I deburred everything, bearings are all new or very recent.
It does have a stock size tick master cylinder. the throw etc. was set up meticulously as well
I guess my options are limited, it’s got to be the throwout bearing or torque tube bearing. Thanks for the help!
check my logic??
bolt backed out of one of the couplers
half of them were properly thread-locked and torqued, the other half were finger tight & backing out!I shoulda caught this when I inspected it a couple months back as part of the clutch job, but there it is.
bolt was rattling up against the bearing. All bearings including the pilot bearing look perfect
One of the PO's had work done by a shoddy shop - they used nice parts but failed the basic stuff in the diff & now the TT.
Good news is it's really minor. Also it took me only about 4hrs to get the drivetrain on the ground, working alone under a set of QuickJacks. I'd rather not do it again though
Lot of work for a minor parteverything is cleaned up, torqued and thread-locked, going back in the next day or 2.
thanks for the help guys!
