C4 going to C5
Old May 31, 2020 | 01:48 PM
BT1991's Avatar
BT1991
Default C4 going to C5
I have sold my C4 and now I am looking at C5. I took the car for a drive yesterday but upon trying to start it the pull key code came across the DIC. The owner said that happens about once a week and he just tries a few times and it starts. He wiggled the key, took it out and turned it over, wiggled a few times and then it started. I drove it and came back to his yard and cycled it a bunch and it fired up every time.
He tells me it has never let him down and it always starts after a few tries. The system cycles and everything seems normal but once in the start position it has nothing. Is this a LMC5 fix or should I be worried about it. He has a new Red Top in it as well.
Any advise is appreciated.
Old May 31, 2020 | 03:00 PM
BT1991's Avatar
BT1991
I just called him and he tells me the LMC5 has been installed. It does still have the open recall on the ignition.
Old May 31, 2020 | 05:44 PM
Cutlassmaster's Avatar
Cutlassmaster
Battery can have an effect also. The LMC5 also has a brown wire mod for certain years if I remember correctly. It may just need that done and it should fix the issue. I would not have the recall done.
Old May 31, 2020 | 07:37 PM
BT1991's Avatar
BT1991
Ok thanks, I will check the brown wire when I pick it up.
Old May 31, 2020 | 09:18 PM
Gary In NM's Avatar
Gary In NM
I installed the LCM5 in my 03Z shortly after buying it. Was still getting the pull key message, did the brown wire mod and it has never come up again.
Old Jun 1, 2020 | 11:21 AM
Supercharged111's Avatar
Supercharged111
Same here on my 04.
Old Jun 1, 2020 | 01:13 PM
BT1991's Avatar
BT1991
Thank you the replies guys. I will look into the brown wire mod once I get the car later this week.
To C4 going to C5
