ignition switch bezel
Old Jun 3, 2020 | 07:34 PM
Jake the Snake's Avatar
Jake the Snake
Default ignition switch bezel
The ignition switch bezel cracked this afternoon, now the key will not turn. The switch is slightly offset within the bezel. Any ideas on a quick fix?
Old Jun 3, 2020 | 09:16 PM
3sACROWD's Avatar
3sACROWD
Reposition the ignition bezel. You may have to remove the radio bezel to do what you need. If you go that far, be aware it takes a good amount of force to pull the ignition bezel off. It pulls straight off.
Old Jun 4, 2020 | 07:56 AM
bjones7131's Avatar
bjones7131
Mine is loose but key still works. I think it is held in place by one screw. Push it around and try and get it loose like mine and you should be able to use the key. Lot of guys have them loose and like me hate to tear into it to replace. See them on EBAY for sale.
Old Jun 5, 2020 | 05:48 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I'm sorry Jake, but I just have to ask. Did you happen to play football in college around the 1996 era? I've never had my switch out yet so I'm sorry for not having any help for you but I had to ask that question though. Good luck with your fix and post back if you figure it out and what the fix was.
Old Jun 5, 2020 | 11:50 PM
Moved to C5 Tech.
Old Jun 6, 2020 | 01:19 PM
craftsman74066's Avatar
craftsman74066
Default ign.switch bezel
my ign.bezel looks just like yours but is not cracked Does this bezel have anything to do with the switch or cylinder.My key is starting to feel rough when turing.The cylinder is off center.Does the bezel centerr support anything
Old Jun 8, 2020 | 10:01 AM
Jake the Snake
NO no college football. I was able to partially remove the radio bezel in my office parking lot and get the car home. I then immediately left to go camping for the weekend. I'll tear into it further this week.
Old Jun 11, 2020 | 02:47 PM
craftsman74066
What holds this bezel in place.Does it snap on or is it the dash.Bezel go on first then the dash.
Old Jun 11, 2020 | 05:22 PM
bjones7131's Avatar
bjones7131
I think one screw, look on ebay, I tried to copy and paste pick of it but no luck, lol.
Old Jun 15, 2020 | 10:24 AM
Jake the Snake
Finally had a few minutes to tear into this. Got the radio bezel out and a better look at the ignition switch bezel. It appears that someone tried to jimmy the switch, I can't imagine how the bezel would crack like it did. I glued it, repositioned it, and put the radio bezel back in place and went to a local car show. Good to go so far. I did order a new bezel, OUCH$
BTW the bezel is held in place by the radio bezel only. The hole in the bezel is for a grommet on a wire.
Old Jun 15, 2020 | 10:48 AM
3sACROWD's Avatar
3sACROWD
I disagree. The ignition bezel is held firmly in place to the dash / ignition cylinder. It takes a significant tug to remove when properly installed. The radio bezel then goes over the ignition bezel but had no holding force applied. When you get your new ignition bezel, it may make more sense.
Old Jun 15, 2020 | 11:37 AM
bjones7131's Avatar
bjones7131
I must b missing it but what holds it in place, you say firmly in place to dash/ignition cylinder, what holds it firmly in place?? Does it pop in place around ignition switch somehow. Saw one on ebay 19 bucks, has a hole in it that I thought would be for a screw??? Thanks
Old Jun 16, 2020 | 10:08 AM
Jake the Snake
3sACROUD is correct it snaps on to the ignition switch but that collar is broken on mine so the radio bezel is all that is holding it right now. The new part when it gets here will snap into place.
To ignition switch bezel
