HVAC Control
Old Jun 5, 2020 | 11:08 PM
Washtubman's Avatar
Washtubman
Default HVAC Control
My **** control for the passenger temp adjustment is not working. Won't display a temp setting and won't adjust up or down. Any ideas for fixing?? Thanks
Old Jun 7, 2020 | 05:18 PM
GCG's Avatar
GCG
At what temperature is the driver's side set?
This is the way the dual-zone HVAC system works in a C5:
When the passenger side is set to the 12:00 (center) position, the driver and passenger side are both set to the temp selected by the driver's side, then the passenger can vary his/her side slightly up and down if desired. This is how it works, unless the driver is set to full up (90°F) or full down (60°F), then the passenger setting will have no effect.
The display will not change with the passenger adjustment.
Old Jun 8, 2020 | 01:52 PM
Washtubman's Avatar
Washtubman
Thanks for that info. At this time, I can't verify that was my situation, but maybe. I sent my controller off to Vettetronics this morning for the dim display fix and replace the leds. I figured for 70.00 it wasn't worth me screwing it up!
Old Jun 9, 2020 | 01:31 AM
BigGun's Avatar
BigGun
Amazing what you can find in the owners manual.
To HVAC Control
