Please help with troubleshooting
Old Jun 6, 2020 | 07:02 PM
nschiff's Avatar
nschiff
Default Please help with troubleshooting
I am getting a check engine light with P0171 and P0174. No mods or upgrades. I cleared the codes but they come back as soon as the engine is up to normal operating temp. Any help wold be appreciated.
Old Jun 6, 2020 | 07:48 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
May be a vacuum leak !!...have you recently cleaned the MAF sensor ????...check the air bridge between the MAF and Throttle Body for leaks or loose connections...do you have a scan tool ??...we can verify with that. PLEASE include the model year and all mods either here or in your profile...this helps us help you !!
Old Jun 7, 2020 | 03:34 PM
nschiff's Avatar
nschiff
C5 Diag You are correct. Vacuum leak PCV - Intake Manifold. Patched it with a small piece of hose and ordered the whole PVC hose. Thanks
Old Jun 7, 2020 | 03:51 PM
C5 Diag's Avatar
C5 Diag
Super !!...I had same thing about 2 years ago...patched the small section of the PCV with black RTV !!
To Please help with troubleshooting
