LS1 idle?
Old Jun 7, 2020 | 08:41 AM
BLUDICE's Avatar
BLUDICE
Default LS1 idle?
How/can I adjust the idle on my ‘98 LS1 - I think the idle is too high.
Old Jun 7, 2020 | 08:54 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
No !!..how high is high ???...TB clean ???
Old Jun 7, 2020 | 09:07 AM
BLUDICE's Avatar
BLUDICE
I just think it’s slightly too high - it’s a automatic transmission and when I put it in drive it seems to want to pull a little harder than my other cars.
Old Jun 7, 2020 | 09:30 AM
helga203's Avatar
helga203
Back to the dealer or a local tuner. It's through the computer. Might be a vacuum leak?? If this is how it's been, them need to adjust computer.
Old Jun 7, 2020 | 09:31 AM
C6_Racer_X's Avatar
C6_Racer_X
There is no mechanical adjustment for idle speed. It's handled by the computer.
is the MIL (SESL or CEL) on? What DTCs are active?
You will need a scan tool or OBD-II Bluetooth dongle with a scan app to diagnose and repair a high idle issue. There's a PID for "desired idle RPM" available in the live data stream. It might be called "target RPM," or "commanded RPM," or something like that. It's usually pretty obvious as the RPM the computer wants the engine running at. Compare that with the actual engine RPM in the data (pay no attention to the gauges in the dash). You'll see one of two conditions.
Most common is the computer wants a low RPM (often around 700 RPM) and the engine is running too fast. That's usually a vacuum leak allowing unmetered air into the engine. If that's what you have, I can post some tips for finding those leaks.
The other situation is where the computer is trying to run the engine at a high idle. This will show the "desired RPM" (whatever your scanner calls it) is high, and the engine is running at the correct high idle speed. That's usually caused by a failing temperature sensor. Either the coolant temperature sensor or the intake air sensor can fail and read extremely cold. Look at those temps in the OBD-II live data. I've seen readings below -50 when sensors (or sensor wiring) fail.
Old Jun 7, 2020 | 09:48 AM
BLUDICE's Avatar
BLUDICE
thank you - sounds like a job for an expert to do - I’m a o’school guy used to working on SBC and flatheads - lol. Thanks again.
To LS1 idle?
