Z06 auto swap wiring question
Old Jun 8, 2020 | 06:48 AM
POPODYNAMO's Avatar
POPODYNAMO
Default Z06 auto swap wiring question
Don’t know if this belongs here or not but I’ll give it a shot. For anyone that has done a manual to automatic conversion, what route did you go wiring wise? I called and talked to rpm about my trans controller and they suggest I use a compushift. Has anyone used a controller or has everyone just ran the factory auto harness with the jumper harness from rpm? Plan on running a manual converter lockup switch as well, so that’s my reasoning behind wanting to run a controller. Tia!
Old Jun 11, 2020 | 08:00 AM
BuddhaZ06's Avatar
BuddhaZ06
Your inbox is full btw.
https://www.ebay.com/itm/121852689687
This pan. 110 shipped and PayPal covered
Old Jun 11, 2020 | 12:08 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Read this thread...
https://www.corvetteforum.com/forums...ap-thread.html
There are quite a few that have done this swap, including me.
You can get an adapter harness made that will plug into the factory auto harness. You’ll have to re-pin some of the PCM stuff, but it’s really easy to do.
Have a tuner do a segment swap and you’ll control the trans thru the pcm/tuning software.
Good luck and have fun!
Old Jun 14, 2020 | 01:16 PM
POPODYNAMO's Avatar
POPODYNAMO
Originally Posted by C5 Pete
Read this thread...
I ended up going this route, thanks!
To Z06 auto swap wiring question
