Mid-America Exhaust mod???
Old Nov 26, 2002 | 10:53 AM
Bob Lineman's Avatar
Bob Lineman
Default Mid-America Exhaust mod???
Has anyone used those little pieces of pipe that Mid-America sells?
They fit between the axle pipe and the outlet pipe of the mufflers.
I was thinking of building my own, but I want to know what people thoughtbefore I hack up a stock exhaust.
Any thoughts would be appreciated.
boB
Old Nov 26, 2002 | 10:58 AM
MaxPower's Avatar
MaxPower
Default Re: Mid-America Exhaust mod??? (Bob Lineman)
Talk to Andy
http://www.aandacorvette.com/
Also run a search for A&A exhuast mod and I think you'll find a wealth of info.
:yesnod:
Old Nov 26, 2002 | 12:16 PM
indyblue98's Avatar
indyblue98
I went shopping around different muffler shops. Got quotes from $80 per side (highest) $50 per side and finally $25 per side. Can't tell much difference in the car,, but out back sounds much better esp when revving 3000 plus. :D
Old Nov 26, 2002 | 12:37 PM
SoCal C5's Avatar
SoCal C5
Default Re: Mid-America Exhaust mod??? (MaxPower)
Talk to Andy
:yesnod:
Andy is the originator of the design. Mid America copied it. You will find it refered to here as the A&A exhaust mod. A&A is Andy's company.
Old Nov 26, 2002 | 07:57 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Mid-America Exhaust mod??? (SoCal C5)
The man himself installed mine on the Power House exhaust by Performance Choice. It does make a difference!
Old Nov 26, 2002 | 08:32 PM
Old Rotor Head's Avatar
Old Rotor Head
I've had the A&A mod for over a year now. At first I was dissatisfied with the results. It took several weeks for everything to settle down and I love the sound now. Very similar to Corsa Indy's. Total cost installed about $100. I don't know if I picked up any HP but I sure sound faster. :D
Old Nov 27, 2002 | 03:17 AM
C5 Frederik's Avatar
C5 Frederik
The best mod to start with. It´s a way to check: loud enough or I will have it louder. For 80 $ you get a sound like some 800 $ exhausts have. Had it on for a year and then upgraded to tthe louder Borla Stinger.
Go and get it.
Frederik
Old Nov 27, 2002 | 08:53 AM
Bob Lineman
Thanx for the input:)))
I'm not expecting a HP gain, I just want the car to sound the way it should w/o spending alot of money. have a great holiday
Old Nov 27, 2002 | 09:47 PM
jmejones's Avatar
jmejones
Default Re: Mid-America Exhaust mod??? (C5 Frederik)
Go and get it.
Frederik
I did this the exact same way. :thumbs:
Old Nov 27, 2002 | 10:13 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
I had the mod installed this morning. My 17 year-old son approves! It now sounds like a vette should.
JohnGlenn's Avatar
JohnGlenn
I made my own. I think they sound good. My brother has Corsa Indys on his '02 and we did a little side-by-side comparison, they sound VERY similiar.
For details and before-n-after sound clips you can visit the "How To" section of my "Corvette Site" at http://www.johndennington.com.
Good Luck.
Old Nov 27, 2002 | 10:14 PM
CCrane65's Avatar
CCrane65
Get it from Andy at A&A. Mid America's is made from aluminized steel where Andy's is made from stainless. Since your exhaust system is stainless it is best to keept the metals the same since they have to be welded. The aluminized steel will melt faster than the stainless.
Old Nov 29, 2002 | 10:32 AM
2kbluestreak's Avatar
2kbluestreak
Default Re: Mid-America Exhaust mod??? (CCrane00)
I made my own for $0.60 with enough galvanized steel pipe from a scrap metal yard left over for 5 more. Did it for the challange. Paid the owner of a garage $20.00 for use of his lift to me to remove and install the mufflers. Welder at work cut the exhaust pipes and welded in the bypass pipes that I had already fabricated. (Probably the best install on the forum as he used a plasma arc for the holes and TIG welded with SS rod making perfect fillets.) It worked as promised. Big thing is no resonance, which some muffler systems are prone to. For a total installed cost of about $120 for most guys, its known on the forum as the "best bang for the buck." If you want to change it out for something different, you've only got a small amount of money in it. :cheers:
Old Nov 29, 2002 | 02:13 PM
JWD01's Avatar
JWD01
If you are talking about the original exhaust - it is NOT stainless steel. It's carbon steel unless of course you have a Z06, then it's Titanium. :yesnod:
Old Nov 30, 2002 | 11:46 AM
jschell's Avatar
jschell
Default Re: Mid-America Exhaust mod??? (JWD01)
I have the A&A exhaust on my car and really like it. I had a Bassani cat back on my last car and it had to much resonance. I'd go with the A&A over many of the $750+ aftermarket system. Great Sound, low budget, no resonance. ENJOY!
Old Nov 30, 2002 | 02:28 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Great, that's what I needed to know! Now only lazyness is keeping me from doing it myself.
To Mid-America Exhaust mod???
