o2 sensors
Old Nov 26, 2002 | 11:43 AM
FastC6Mike's Avatar
FastC6Mike
Default o2 sensors
Would there be a decrease in performance if the o2 sensors failed?
Thank you.
Old Nov 26, 2002 | 01:05 PM
lyonsh's Avatar
lyonsh
Default Re: o2 sensors (98MechamFormula)
Yes. Your PCM uses the O2 sensor inputs to adjust the fuel trim as required by the way you're driving the car. With the O2 sensors not functioning, it goes into a default "open loop" mode (actually, it starts in this mode until the sensors have time to heat up and provide accurate readings). The default mode is a "middle average" setting, not ideal across the board.
