Brake / hazard light electrical issue
Old Jun 13, 2020 | 04:15 PM
Ran-D's Avatar
Ran-D
Default Brake / hazard light electrical issue
Had my 2001 C5 Corvette detailed, including under the hood, last week and now don’t have the 4 main brake lights (upper center ok). The same 4 lights don’t light up when engaging the hazard / emergency button (the 2 front markers are working). I ran a continuity check on passenger fuse box 5, 8, 15 and engine fuse box 6, 52, 53 - all ok. The turn signals work. Electrical is NOT my strong suite. A ground or connect(s) perhaps? Any electrical people out there with suggestions? The more detail the better.
Old Jun 13, 2020 | 06:33 PM
SilverC54me's Avatar
SilverC54me
From your description of the issue, it is likely a faulty Hazard switch. Push the hazard button several times in a row. Some times the contacts within the switch get grimy and repeated pushing of the button temporarily cleans them. If it works after this then you would need to replace the switch. However, it would not be out of the realm of possibilities for all 4 taillight bulbs to be bad.
Gary
Old Jun 13, 2020 | 09:41 PM
Moved to C5 Tech.
Old Jun 14, 2020 | 05:10 PM
Ran-D's Avatar
Ran-D
Gary
If I disconnect the hazard light switch, would /should the brake lights work?
Old Jun 14, 2020 | 05:21 PM
SilverC54me
No, brake lights circuit goes through the hazard switch.
Have you pushed the hazard switch 10 or so times in a row? Did anything change?
Have you checked the bulbs?
Gary
Old Jun 14, 2020 | 06:38 PM
Ran-D's Avatar
Ran-D
Gary
I've tried the hazard button 10 times slow and 10 times fast, plus I replaced 1 bulb even though the oem tested ok. Still no main brake lights. I had changed the MFS a couple of years ago for turn signal and popup headlight issues. A few months ago the turn signal wouldn't go on, but discovered an on and off of the hazard switch would start them up again. Maybe it's been the hazard switch all along????
Old Jun 14, 2020 | 06:54 PM
SilverC54me
Yes, it could be the hazard switch.
Gary
Old Jun 14, 2020 | 07:21 PM
Ran-D's Avatar
Ran-D
Gary
Do you know which / where ground is connected with the brake system?
Old Jun 15, 2020 | 12:51 AM
SilverC54me
From your original post,
1. The brake lights do not work except for the center LED bar.
2. Turn signals do work on the rear.
3. Hazard does not work on rear.
Do you have LED's installed in the front turn signals/DRLs? If so do you have a hyperflash harness installed? If yes to both of these then the Hazard switch is the issue. Just got through fixing a similar problem on a 99 with no brake lights except for the center one. Failure is in the hazard switch.
Gary
Old Jun 15, 2020 | 01:56 AM
Ran-D's Avatar
Ran-D
Gary
All bulbs are original. I saw a post mentioning hyperflash harnesses and thought that was original equipment. No mods to any lights or light wiring.
Old Jun 15, 2020 | 11:15 AM
SilverC54me
Replace the Hazard switch.
Gary
Old Jun 15, 2020 | 01:52 PM
Ran-D's Avatar
Ran-D
I'll be ordering a hazard switch today. Do you know if it's easier to replace by removing the driver knee pad or by removing the center console and radio?
Gary, thanks for all of your input.
Randy
Old Jun 15, 2020 | 02:02 PM
SilverC54me
You will have to remove the center console, radio surround and knee bolster. It will also be necessary to remove the radio.
The hazard switch is mounted in such a way that one of the lock tabs is in a position you cannot see it got to do it by feel.
Let me know if you need help with changing it out. I am over by Disneyland.
Gary
Old Jun 15, 2020 | 04:02 PM
Ran-D's Avatar
Ran-D
Very kind offer. I moved to the Tucson area last year and never thought about updating my profile til now. I'll keep you posted on my progress.
Old Jun 17, 2020 | 12:50 AM
Ran-D's Avatar
Ran-D
Is the AC Delco part available anywhere or is Dorman # 924-609 the only replacement part available?
Old Jun 20, 2020 | 03:15 PM
Brian Smith's Avatar
Brian Smith
Ran-D that seems to be the only option. RockAuto has this one and no stock in the other one they have listed.
https://www.rockauto.com/en/catalog/...ng+switch,4468
This makes the third one I have replaced. The Dorman 924-609. I've seen postings, since this last failure, that suggest pushing the emergency flasher multiple times a week to avoid this I date the things when I install them and today's is dated 11/8/2019. The one before that was dated 4/2014. I paid about $23 at O'Rielley.
It now takes about 10 minutes to get to the switch. One SHOULD NOT GET GOOD AT CONSOLE/DASH DISASSEMBLY!!
Old Jun 21, 2020 | 10:08 AM
lionelhutz's Avatar
lionelhutz
The brake power goes into the hazard on a white wire and comes out of the hazard switch on a brown wire. The brown wire goes to the turn signal switch. Check voltages on those wires if you want to confirm it's the hazard switch you'll find voltage on the white and no voltage on the brown.
There is an inline splice connector for the hazard under the ignition switch that is easier to get to.
Old Jul 13, 2020 | 08:06 PM
Ran-D's Avatar
Ran-D
Yikes - I just plugged in a new Dorman hazard switch and still no brake lights. Dumb question - I have a voltage tester, exactly how do I test the switch? I hate guessing and don't want to start replacing everything unnecessarily.
1) Bad new hazard switch?
2) Brake light switch?
3) MFS?
4) Other ideas?
5) Pull my remaining few hairs out?
6) Give up and go to service shop?
To Brake / hazard light electrical issue
