Low gear acceleration
Old Jun 13, 2020 | 07:14 PM
Bstan1009's Avatar
Bstan1009
Default Low gear acceleration
I dont run my vettes hard esp from 0. I have noticed, however, that in driving my c5 corvette with very little gas it seems to not accelerate as fast as the cars around me, but with equal pressure my 1993 c4 and my BMW e38 both seem to pick up quickly. Once I put a little more gas down the. C5 accelerates faster than all, by far. Just curious if this is just how the car is designed or if an issue. Maybe the borla exaust makes me feel like I'm giving it more gas than I am but it for sure doesn't feel like it.
Old Jun 13, 2020 | 07:20 PM
StingrayRebel's Avatar
StingrayRebel
the throttle response is not the best but it can be fixed with tuning, I wouldn't rush out just to do that but if you have any mods planned you can get that taken care of when you get tuned for the other mods... you also don't need any add on throttle units that are sold by some vendors, an experienced tuner can accomplish the same thing without having to buy anything else
Old Jun 13, 2020 | 08:53 PM
k24556's Avatar
k24556
Well with very little gas in the tank, the fuel pump could momentarily have reduced delivery, which will lean things out, and if the car knocks, pull timing. If the car runs ok with a full tank, why not put gas in the tank before you drive.?
Old Jun 13, 2020 | 09:01 PM
StingrayRebel
I think he means gas as in throttle and not gasoline in the tank lol
Old Jun 14, 2020 | 08:53 AM
wydopnthrtl's Avatar
wydopnthrtl
Just as a maintenance item to help rule it out...
- Disconnect the battery
- Disassemble the intake between the air filter and the intake manifold and get MAF and throttle body on the bench.
- Clean the MAF w/a Q-tip and the proper cleaner (TB spray cleaner or electrical contact spray cleaner)
------**be very soft with the MAF wires and let the cleaner and Q-tip fibers do the cleaning. Put no pressure on them**
- Clean the TB w/spray cleaner and an old toothbrush
- Reassemble intake parts (you can reuse the C5 TB gasket)
- Turn headlights on then off (clears any stored memory)
- Reconnect battery.
- Turn ignition on but don't start the engine.
- Floor the throttle twice.
- Key off.
Now the computer will re-learn the MAF signal and you can at least rule out dirty induction parts.
(I do this every 20k miles or so on all my cars. Sometimes its surprising how much better it idles and throttle response is improved)
If that's all good and you still want more. A mail order tune (or local dyno tune) with specific instructions like "I want more tip-in response" will give you that feeling of instant power w/only little throttle input.
(Doug at ECS can give you a very good mail order tune for only $150 I used him and am well pleased (I have personally tuned Fords 10+yrs ago))
Old Jun 14, 2020 | 11:03 AM
Gordy M's Avatar
Gordy M
The PCM has some "throttle decay" built into the logarithm, most refer it to throttle lag. With tuning, it can be changed to a more responsive throttle control, but never have a tuner remove all of it because the car will be extremely hard to drive at low speeds like parking or backing up.
Old Jun 14, 2020 | 03:44 PM
tabbruzz's Avatar
tabbruzz
auto with 2.73 gears ???
Old Jun 15, 2020 | 11:39 AM
Bstan1009's Avatar
Bstan1009
- Key off.
thank you so much for the detailed advice. I have just completed the steps as described. On first crank the car had a little issue but then it cranked right up and has cranked perfectly since. I have not had chance to actually drive it yet as today is of course 100% chance of rain all day and raining heavy but I will for sure get on road soon to see if it helped. Already seems to have adjusted based on hitting the gas and acceleration response of the engine but driving will tell for sure. I will update later today. Thanks!
Old Jun 18, 2020 | 10:11 PM
Bstan1009's Avatar
Bstan1009
I found out mine is also the 3.15 performance gear axle ratio and not the stock 2.73 axle. I was wondering if doing an intake cleaning using seafoam and hot soak would help alleviate the issue? Anyone?
Old Jun 18, 2020 | 11:38 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
On all GM cars and trks with the drive by wire throttle YES there is a horrible delay in throttle response
Let's say you are at a stop light and floor the throttle to wide open---You think it's wide open but it's NOT The DBY throttle does not allow the t-body blade to go to 100% until you reach approx 3600 RPM's !!! so before 3600 the throttle is barely cracked open !!! This is a one entry tuning fix--which will make your throttle work as if it were a cable throttle
Old Jun 19, 2020 | 12:14 AM
Bstan1009's Avatar
Bstan1009
okay so this is normal? that make me feel better if so
To Low gear acceleration
