Air Pump for '98
Old Apr 27, 2024 | 06:32 PM
dgbase's Avatar
dgbase
Default orrection
Website:
BZrebuilders.com
I ended up having Erik & Cirillo @ BZ rebuilders check air pump.Definitely was not working due to carbon debris & wear x 25 yrs They rebuilt it in 2 hrs, guarantee 1 yr.warranty- Cost $250
,It works like a charm after re-installing it on a cold start.
Old Apr 27, 2024 | 06:33 PM
dgbase's Avatar
dgbase
Default correction: sprayed Seafoam
Sprayed seafoam
Old May 10, 2024 | 12:50 AM
dgbase's Avatar
dgbase
Default Return of the PO410
Well, the saga continues, the rebuilt air pump activated twice for 1 min-45 secs on 2 different cold starts.
PO 410 returned, so over weekend I pulled intake manifold and changed out 2nd air valve. Definitely not able to blow it through it. I drove it once and PO410 code returned, stated possibly a relay issue or solenoid issue.The previous mechanic said he checked the solenoid & vacuum under the passenger front wheel guard area, but I am a little suspect.
Any ideas how to proceed next after checking changing #33 and Max fuse in position #50 in fuse box under hood. Thanks for any suggestions- I plan to take it back to a Smog repair shop next, since it failed smog testing at that time due to air pump faulty recognition.It passed the emissions part of the test.
Dejay
Old Nov 24, 2024 | 05:52 PM
vectorz's Avatar
vectorz
Dejay
Did you ever fix it ?
Old Nov 24, 2024 | 08:58 PM
dgbase's Avatar
dgbase
Default Air Pump Malfunction - Failed smog check
Yes. I ended up replacing both valves, of course the one behind manifold was defective and the Air Pump was not working. I removed it and had it re- built for $250 with B-Z rebuilders ,818-703-9228, 7745 Alabama Ave, Unit 2,Canoga Park,CA 91304- Eric the owner- had his technician clean it and rebuilt worn out parts in one hour while I waited. It's been working fine ever since and it passed the Smog
Re-check after the repair. Thanks for your inquiry since this Air pump is no longer manufactured.The State DMV referred referred me to a guy in Sacramento that wanted $350 plus shipping for a used one, with no guarantee.
Old Nov 25, 2024 | 10:59 AM
Fast one's Avatar
Fast one
If the codes are turned off for the pump and check valves but the pump and valves remain in place will the car pass inspection?
Old Nov 25, 2024 | 12:20 PM
dgbase's Avatar
dgbase
Default reply
Fast one,
I doubt this would pass Smog Inspection in California, since there are 2 components necessary to pass on the electronic Smog Testing. The first is clearance of CO2vemissions below the state accepted levels. My car initially passed this even with a defective Smog pump.
The second component, checking directly the Smog pump function initially failed until the pump was repaired, since the Smog Test Center is able to detect if the codes demonstrate the Smog pump is malfunctioning with startup or fails to respond. If it fails to pass, the owner has to contact a DMV referree to determine a solution ,which usually will be costly.
So, I would try to repair it first after the first Smog Test failure to avoid the DMV referree decision.The BZ site can fix it if you call them & ship it to them .Talk with Eric,the owner, who has been in business there over 40 years.I wish you good luck.
