Transmission
Old Jun 14, 2020 | 11:47 PM
Collinsfarm's Avatar
Collinsfarm
1st Gear
Default Transmission
Hey all I am very new to this site but not new to mechanics. So I found a 02 base corvette built up engine but bad transmission and my question for all the gurus out there is, since the transmission is a 4l60e I have a 03 1500 truck with a 4l60e could I swap them out and how hard would it be? I know as of right now it would be like the tail shaft and maybe bell housing but would it work? And also maybe the input and output shaft but has someone else done this yet and has some guidance for me?
Old Jun 15, 2020 | 04:13 PM
foggy's Avatar
foggy
Absolutely Not
Your C5 Trans is mounted directly to the rear end. And NOT an LS style trans.
Old Jun 16, 2020 | 08:45 AM
RichyB33's Avatar
RichyB33
A 4l60e isn't that expensive to rebuild if you can pull it yourself and take to a good trans shop.
Old Jun 16, 2020 | 03:03 PM
Moved to C5 Tech.
To Transmission
