Battery Issue
Old Jun 22, 2020 | 12:04 PM
DERIII's Avatar
DERIII
Cruising
Default Battery Issue
2000 C5, 78,000 miles...After about a 3 hour drive, stopped for fuel. When tried to re crank, it clicked about twice before firing up. When I got home and tried it several hours later, nothing worked. Put the charger on and full charge in less than 10 minutes. Battery is less than a year old and driving yesterday, volt meter gauge and digital all showed charging at 13.8 -14.2. Ideas appreciated.
Old Jun 22, 2020 | 01:23 PM
mmartinez's Avatar
mmartinez
Probably not the battery, could be your starter, but to make sure have your battery load tested at a auto parts store, and rule out the battery as your problem.
Old Jun 22, 2020 | 07:43 PM
BigGun's Avatar
BigGun
Make sure the battery cables are tight. You should not be able to turn them on the post by hand.
Old Jun 25, 2020 | 08:29 PM
jackthelad's Avatar
jackthelad
If those connections are not perfect, all kinds of problems result. Try unscrewing the terminal screws, scraping/sanding to make sure there is no corrosion, smearing everything with Vaseline and re-assembling.
To Battery Issue
