Inspection
Old Jun 24, 2020 | 12:43 AM
Dwhaynie's Avatar
Dwhaynie
6th Gear
Default Inspection
I have a 2002 C5, I haven’t been able to pass the inspection due to P0410 code. I have change out the upstream o2 sensors, the air pump, drove it 100 miles.
Im at my witts end on this. Any suggestions on what’s left that I may be overlooking, would greatly be appreciated.
Old Jun 24, 2020 | 01:13 PM
HydroPWR's Avatar
HydroPWR
5th Gear
I had this code pop up on my DIC just prior to working on my car. I was replacing the small vacuum line off the map sensor on the back of the intake manifold that goes to the vacuum reservoir. I had a pretty big vacuum leak, which is the common reason for the interior vents not operating correctly, that was throwing my lean codes in addition to the P0410 being in. During this I had removed the intake and intake manifold. It my case, for the P0410, it could have been an issue with the vacuum line or possibly the 1 inch (aprox) air hose that enters the intake box from the drivers side having a kink in it. I am not sure which of these issues was the cause, or which one fixed it, but the code cleared and has not come back since (over 3 weeks and several hundred miles. Hope this is helpful to you.
Old Jun 24, 2020 | 03:28 PM
SilverC54me's Avatar
SilverC54me
Most likely the small vacuum line that starts at the back of the manifold and goes to the vacuum canister in the passenger fender area.
This is known to deteriorate over time and if a battery ever leaked the deterioration would be accelerated.
One quick check as was mentioned in the above post, to the HVAC vents work properly. If you set it for defrost does the air only come out of the top dash vent? If set to the foot wells does air only come out of them. If the answer is that no matter what setting the vents are set to air comes out of all, then the vacuum line is bad.
The AIR pump on 2000 and up C5's has a vacuum controlled valve next to the air pump. If this valve does not open then you get the P0410. It is a 90% chance that the issue is around the battery and vacuum canister area. It may require replacing the vacuum line from the intake manifold to the vacuum canister. Been there done that on multiple C5's.
Gary
Old Jun 24, 2020 | 05:06 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
First off it was probably unnecessary to replace the O2’s for a P0410 !!...yes, the O2’s are looked at to make sure they go lean during the test...if you have a Tech 2 or any bi directional scan tool it’s a pretty easy diagnosis...does the air pump operate when the car is initially started when cold ??...yes, the system need vacuum to the solenoid (above PCM) and when open allows the diverter valve (if OK) on the AIR pump to open allowing the pump to allow air flow into the exhaust manifold...You can see if you have vacuum at the diverter valve vacuum line when the pump comes on but the PCM’s AIR test only happens when the system is in “closed loop”...the AIR solenoid is ground side switched so with the key ON if you take a 12 volt test light connected to ground and touch it to the purple (control) wire on the solenoid by back probing it you should hear the solenoid “click” !!...make sure you have 12 volts on the pink wire too !!.., it can even be a bad driver that is not allowing the ground to work at the PCM... if that were the case you would need a new PCM
enclosed is a good video (2 parts) explaining the system...you MUST understand the theory and operation before trying to diagnosis !!
Old Jun 26, 2020 | 02:24 PM
Dwhaynie's Avatar
Dwhaynie
6th Gear
I forgot to mention that I also changed out both check valves.
im still having trouble finding the solenoid for the air pump system.
Old Jun 26, 2020 | 02:29 PM
C5 Diag's Avatar
C5 Diag
Above the PCM !!
Old Aug 1, 2020 | 02:36 PM
Dwhaynie's Avatar
Dwhaynie
6th Gear
I’m just now getting back to work on this problem, now the air pump works.
the inspection report says the the catalyst is not ready and ho2 is not ready also
any ideas on what to do would be great
and I have changed out the upstream o2 sensors also.
Thanks for any help with this problem
To Inspection
