Cost to replace AC Condenser?
Old Jun 24, 2020 | 11:37 AM
Choreo's Avatar
Choreo
Default Cost to replace AC Condenser?
I still have to investigate, but I think my AC condenser is leaking oil? Is that possible?
I have noticed on my garage floor drops of yellow oil dripping occasionally from the front left radiator guard rail (far in front of the steering rack). All I can figure that is that far forward is the AC Condenser - just never heard of one dripping oil?
If that is what is wrong, approximately what should it cost to have it replaced? I can't do it myself currently.
Old Jun 24, 2020 | 12:49 PM
RonSSNova's Avatar
RonSSNova
Happened to me as well. Forever I thought it was a tiny leak at my B&M trans cooler. Never dripped though.
When I pulled the engine a month ago I went ahead and pulled the radiator and AC condenser. There was no charge left in the AC so what the heck. Lower right of the condenser was black from the leak and accumulated dirt.
Now I know why the AC would not stay charged.
No clue what a shop would charge to replace it. The part itself is a couple hundred bucks. I’d guess though the job won’t be cheap. Labor to R&R, refill the cooling system, charge the AC etc. it will add up.
Old Jun 25, 2020 | 02:44 AM
Choreo's Avatar
Choreo
What is amazing is that I first noticed the drops almost a year ago and have been watching my engine oil and power steering fluid levels, but they never went down. Also my AC is still freezing cold! The system must hold a LOT of oil!
Old Jun 25, 2020 | 08:36 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
If you leak enough oil eventually you will seize the compressor. Don't know how long you can go like that. It's also interesting that you are not loosing freon and it's still cold. I guess if the leak gets bad enough that you start losing cold air it will.be.time to replace it.
Old Jun 25, 2020 | 08:44 AM
RichyB33's Avatar
RichyB33
The condenser isn't that expensive. They aren't that big of a deal to change yourself wither. The real cost is in the recharging of the system. I need a new compressor and recharge, but am holding off until after my motor swap is done.
Old Jun 25, 2020 | 03:55 PM
RonSSNova's Avatar
RonSSNova
Interesting that your AC still worked. Mine would last a month. I got free recharges at the shop I worked for, but it became pointless.
I did tuning and performance work, I’m not an AC tech😊
Like RichyB33, I’m doing an engine swap, I’m seriously considering leaving the AC off the car. For now anyway....
Doesn't get all that hot in Oregon
Old Jun 25, 2020 | 06:24 PM
OregonDan's Avatar
OregonDan
I had my A/C system repaired last fall. New compressor, drier, evap tube, condenser and labor with a 2 year warranty on parts and lifetime labor warranty was $822.34.
Old Jun 25, 2020 | 10:46 PM
Choreo's Avatar
Choreo
Was that from a Dealership or independent service center?
Old Jun 26, 2020 | 09:45 AM
OregonDan's Avatar
OregonDan
Local stand-alone shop. I only go to dealers when I'm desperate or forced to by the warranty company.
Old Jun 26, 2020 | 07:38 PM
ncali's Avatar
ncali
Choreo: your ac condenser is not leaking oil. If it were you would not have a cold ac. The condenser usually holds 2 oz of oil. The refrigerant would leak out long before the oil
If you have an auto trans I would look at the cooling lines
To Cost to replace AC Condenser?
