How to: Flex Fuel on C5
Old Feb 23, 2024 | 11:44 AM
  #121
VETTEYOG's Avatar
VETTEYOG
2024 C5of the Year Finalist - Unmodified
Originally Posted by aaronc7
Another option would be for me to read it with PCM Hammer and then post the .bin file--then guys could flash it via open source means to enable FF, then go about their tuning per normal that way or hpt or efi.
I know this is an old post, but would the OP be able to post the "BIN" and "XDF" files? I would like to try this on my 2001. I haven't made the leap to HPT yet, and use TunerPro and PCM Hammer.
Old Feb 23, 2024 | 11:56 AM
  #122
aaronc7's Avatar
aaronc7
I could, however over on PCMhacking.net they have very extensive XDF for the -7603 OS and a "1 click patch" in tunerpro to enable flex fuel on the file. That should get you exactly what you need to get started and is actually easier and more straight forward than using HPT. I set up a few of the flex fuel tables differently than how that "patch" does it, but it at least will highlight the diffs of all of the tables that you should take a look at when moving to flex fuel. IIRC it looked like it mostly copied over values/tables from (probably) a 03 Tahoe file.
Old Apr 24, 2024 | 02:41 PM
  #123
jfisher1191's Avatar
jfisher1191
3rd Gear
Has there ever been flex fuel enabled file made for the 12592425 OS? Unfortunately used my HPT credits before finding this and wanting to play with Flex Fuel and cannot for the life of me find a truck Flex OS of the same to merge from.
Any help greatly appreciated
Old Apr 24, 2024 | 02:51 PM
  #124
benflynn's Avatar
benflynn
If you have extended parameters on hpt u can fill out the missing tables
Old Apr 24, 2024 | 03:48 PM
  #125
jfisher1191
3rd Gear
Ahh at that point it would be cheaper to just license the other OS and use it instead unless Im missing something of course
Old Apr 24, 2024 | 07:56 PM
  #126
aaronc7's Avatar
aaronc7
Send me your current or stock read or whatever file and I'll populate the FF tables for you. 12592425 calibration table layout is same as -7603.
edit: HPT does have better definitions for 7603 vs 2425. Nothing huge but they are different and 2425 is missing a few. Recently compared them in depth helping set up a friend who was on 2425. We decided to just go 7603 from the get-go.
Old Apr 24, 2024 | 09:40 PM
  #127
smitty2919's Avatar
smitty2919
AFAIK, anything truck OS related you still have issues getting the fuel gauge to work right since Corvettes have dual tanks and trucks do not.
I think it's best to start with the 7603 2004 Corvette OS and simply enable FF.
Old Apr 24, 2024 | 11:15 PM
  #128
Supercharged111's Avatar
Supercharged111
I wonder if it's not just as simple as swapping in the system segment to a truck tune to get the fuel gauge, HID, etc to work properly? But for me it was plenty simple to just use the cax file and copy/paste over all the applicable stuff from the truck tune.
Old Apr 25, 2024 | 07:26 AM
  #129
smitty2919's Avatar
smitty2919
I can't speak to any of this, but I know when I watched my tuner "enable FF" it was as simple as checking a box...
Swapping in segments may be "easy" for some, but IMO K.I.S.S. Segment swapping also lends to more errors/issues.
Old Apr 25, 2024 | 08:17 AM
  #130
aaronc7's Avatar
aaronc7
12592425 is only available for 2004 C5s, it was an update that was part of the whole column lock recall. So whether you start with the -2425 or -7603 C5 file as your base, you'll be good to go. The two calibrations even have the exact same CVN, the only change was the OS/application software logic side of things.
File Type: hpt
File Type: hpt
Old Apr 25, 2024 | 08:34 AM
  #131
smitty2919's Avatar
smitty2919
@aaronc7 to the rescue again!
Your help on supplying the OS files was a life saver after the other (unrelated OS) issues I had. Thank you again!
Been enjoying that sweet corn smell since July 2023 and haven't skipped a beat!
Old Jun 15, 2024 | 11:09 PM
  #132
TheAntiChrysler's Avatar
TheAntiChrysler
Cruising
I looked all over before just creating some 2004 bin files. I actually could only find an M6 file and needed the A4 so I just created it. Then I realized there is 7 pages of this thread. I will be doing a write up on my experience trying to do this soon as my pcm is ready, my gauge/sensor is installed and working, and my injectors are tested. Now I just need to install the injectors then swap the computer and continue testing. Either way hop these files can help someone. Sorry I took it away from stock for the A4, but I adjusted it to where my 02 is on and many of the adjustments were inherited and I am slowly moving things around in it. Odd thing is it runs fine and never gets to 200F even on a 7 hour drive through the Appalachians in late May. Thank you for your help and any suggestions welcomed as I also attached my hpt file. Big thank you to @aaronc7
File Type: bin
File Type: hpt
Old Jun 17, 2024 | 09:43 AM
  #133
aaronc7's Avatar
aaronc7
Are you using HPT or PCM hammer (are you wanting to use the bin or hpt file, I'm confused)?
The HPT file is locked too
Old Jun 17, 2024 | 08:05 PM
  #134
TheAntiChrysler
Cruising
Yeah sorry for the confusion. I am bad at talking to myself and thinking I typed something I said to myself. I DM what I was attempting which again I wanted to see if I could flash with PCM Hammer the P59 so the PCU went into HP tuners already looking like it was a 04 vette instead of a 03 Yukon. Yes I know HP would overwrite it, but I also wanted to see if I could trick HP tuners to think it was my car already, but it is reading hardware level IDs which would take a little more deep diving into 20 year old hardware to get it to line up and I would probably cause some other side effects if I tried so I am just gonna disable VATs worst case, but I will be swapping the PCM this weekend.
Also does anyone have a wideband wired in on a P59? If so can it still go in through Blue 55 and read through the EGR or does it have to go another route like the AC. Which if it does then I may wait on injectors and putting E85 in until it is below 95 every day.
Old Jun 18, 2024 | 08:30 AM
  #135
aaronc7's Avatar
aaronc7
I have my wideband going thru the EGR pin just like I did on the P01-- works fine/works the same. I think the toggle is in the xdf I posted as well.
Old Jun 18, 2024 | 08:33 AM
  #136
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default E85 near San Francisco,CA
I’m interested in running E85 on a 99 supercharged coupe. Where could I get help installing and tuning it near San Francisco?
Old Jun 19, 2024 | 12:15 PM
  #137
smitty2919's Avatar
smitty2919
This isn't a very widely known mod to do for you to hand it over to a shop unless they are well versed in the C5.
You need the correct version PCM (and correct OS)
You need to swap some pins in the car harness going to the PCM
E85 FF sensor
Injectors
Proper dyno tune
May want to explain the scope of the work to whatever shop does the work.
To How to: Flex Fuel on C5
Old Jun 28, 2024 | 11:51 AM
  #138
TheAntiChrysler
Cruising
So for everyone @aaronc7 I am having issues with the EGR and FF sensor reading on any logger including Universal Patcher via OBDLink or HPT. The hardware is off a 03 FlexFuel L59 Yukon XL, thus physical provisions should be there in theory.
Here is the bin and hpt for what is most current in my car. I have tried diving pretty deep into this, and I may just grab one of the files posted in OP and try a reflash. The tune on this isn't stock, nor is it mine (previous owner did it), and I have been slowly figuring it out at the same time I never took it back to complete stock cause the engine never goes reach 200F and the way it runs is alright. Yes I know the transmissions has extra pressure on it in the current set up. Another thing that I was thinking is it could be an auto disable based on something else being disabled like the LTFT.
File Type: hpt
File Type: bin
Old Jun 28, 2024 | 01:38 PM
  #139
aaronc7's Avatar
aaronc7
Quickly looked over it, and the FF stuff looks good to me, not sure why you can't see anything in the scanner.
Sometimes you have to run the car for a while for it to update, not sure if you've tried that yet.
I don't think HPT has it, but I believe there is a 2nd parameter that you can log, which is actual FF sensor hz output. This can help determine if the sensor has a hardware/wiring issue vs something with the tune. EFILive had this iirc.
Here's a file with EGR enabled at least
File Type: hpt
Old Jul 28, 2024 | 04:10 PM
  #140
aaronc7's Avatar
aaronc7
Updated original post with new FF enabled files (v5) and updated XDF. The C5 base M6 file I had was actually A4 file. Not sure I downloaded the wrong file off the repository years ago, but it should be good to go now.
