How to: Flex Fuel on C5
Old Jul 28, 2024 | 05:22 PM
  #141
TastyBacon's Avatar
TastyBacon
Interesting, thanks again for this. I've been running v3 on my M6 car for a couple years now and it's been working great. I can't remember whether I started with one of your .hpt files or whether I pulled a stock '04 Z06 file from the tune repo as a starting point, though. Do you think there's any reason to mess with it?
Old Jul 28, 2024 | 08:27 PM
  #142
aaronc7's Avatar
aaronc7
Probably not, there's quite a few diffs in idle spark and stuff like that you'd expect between a MT and AT car. The throttle mapping is quite a bit different too, which kind of surprised me (A4 is a lot more aggressive in normal mode... as in TC on and not in comp driving mode).
Worth a look/compare probably, but if you're happy with it, no reason to mess with it. If it was me, next time I changed something significant or was bored I'd probably start over from scratch with the stock M6 file.
Old Oct 8, 2024 | 04:49 PM
  #143
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Did the P59 ECUs start with the transition to the C6 style fuel system in late '03, or was it for the '04 model year?
Old Oct 8, 2024 | 09:20 PM
  #144
aaronc7's Avatar
aaronc7
C6 fuel style started mid 2003.... 2003.5 model year if you will. They still had P01.
I have a 2003.5 coincidentally.
Old Sep 18, 2025 | 06:35 PM
  #145
beaucooper's Avatar
beaucooper
3rd Gear
What injectors are you running with the e85?
Old Sep 19, 2025 | 03:02 PM
  #146
smitty2919's Avatar
smitty2919
Any injector that is said to be E85 safe. Flow rate will depend on what your motor needs. I think rule of thumb is 30% higher usage of E85.
Old Sep 21, 2025 | 09:33 AM
  #147
aaronc7's Avatar
aaronc7
I'm running 12613412 - 51lb L96
Converted Gen4 injector data into Gen3 format, turned out well.
Old Sep 25, 2025 | 04:29 PM
  #148
Bpaschke's Avatar
Bpaschke
2023 C5 of the Year Finalist - Modified
Great writeup on this thread. I'm thinking about taking my supercharged 02 down this rabbit hole. Hoping for a cheap/easy large power increase.
Old Mar 11, 2026 | 11:16 AM
  #149
TwoShoes's Avatar
TwoShoes
1st Gear
aaronc7. I am finishing motor build on my 2002 C5, forged bottom end, twin 55mm precision turbos, and so on. Now I am at the point of figuring out E85 as the 91 octane varies so much here in Nebraska and I would like to get away from meth injection that I was running on this setup previously. I have read through this thread and it has some really good information. With it being a 2002 what would be your suggestion on going about E85 conversion ECU and programming wise?
Old Mar 11, 2026 | 11:22 AM
  #150
smitty2919's Avatar
smitty2919
I would assume the same that has been discussed. An PCM and Operating System from a car that you can enable E85 (2004 C5 OS variant is a sure thing), and then all supporting parts for the fuel system. Size your pumps and injectors accordingly.
Old Mar 11, 2026 | 11:44 AM
  #151
Supercharged111's Avatar
Supercharged111
You say you've read this thread, but go on to ask precisely what this thread addresses right out of the gate. . .
Old Mar 11, 2026 | 09:17 PM
  #152
aaronc7's Avatar
aaronc7
This thread doesn't specifically address the 2002 to 2004 wiring changes, but I know that info is on the forums.
Once you get that aspect figured out, then you should be able to follow this as written.
All I did was look at 2003 and 2004 pin out to see what moved and where, and I moved the pins in the harness.
You'll likely want to do some 2002 vs 2004 file diffing and copy over things that make sense. One thing I can think of is the 2002 fuel system is slightly different so you I'd copy over the fuel level sensor scaling values to ensure maximum accuracy. Just one example.
Old Mar 12, 2026 | 08:39 AM
  #153
smitty2919's Avatar
smitty2919
I agree. I printed out a 2003 to 2004 PCM wiring harness and one for one matched up the pins.
Do the same with your 2002 and 2004 to confirm the same pinning is needed.
