TSP Cam question
How do you like the cam?
This cam good far as driveability?
I'm looking for driveability with mods.
will my automatic trans handle this much hp w/stall?
Any input is appreciated.
Also should i replace lifters? Why? What kind?
What oil pump & timing chain?
Do i need to upgrade other parts such as fuel injectors, etc?
There are a thousand varying opinions on the other items you mentioned - the bottom line is don't cheap out and buy chinese lifters, oil pumps, etc. A quality set of lifters will save you MANY headaches in the future. You will probably need to change the springs on your heads at a minimum, or will end up doing it shortly after completion, with the OEM set having 37k miles. That cam can use beehive springs, but I would put a fresh set on for sure. Get a quality timing chain, preferably a single roller JWIS / IWIS chain, which is the manufacturer of the Katech C5R, Rollmaster, and a couple of other brands. A quality oil pump from melling is the go-to in the LS1 motor, with high volume / high pressure being up for debate and preference.
Injector size is another guess - you may be completely fine with your current OEM setup, or may need to step up one level. You will get many varying opinions on this as well - I am very much a "put in the parts with room to grow" mentality, so I would likely go up in injector size if I were you.
The BTR and TSP V2 cams are both great off the shelf grinds, with neither being superior in the end for a street driven car. They are kind of like different paths leading to the same destination.
thank you for your input i aporeciate it. Yes I'm going toreplace the lifters, oil pu.p,and tim8ng chain with quality brand. I've teadsome posts where some on mentioned thec5 a/t can handle 450 hp but it was just broefly mentioned not confirmed. Also didn't know that was at the crank or Rwhp.
I personally feel the 228R is the best LS1 cam but that is just my opinion.
I feel the PRC .660 dual springs are hard on lifters when not necessary. Lifters go with Morel or Johnston (link bar if you can swing it,wish I splurged on them now myself). Katech C5R chain and a melling oil pump for sure. Or you can get the ported LS6 that TSP offers. A couple of small washers in with the spring can bump up pressure on it slightly. Also some type of rocker arm upgrade to the trunnion.
