Crazy C5 HVAC issue
Old Jul 13, 2020 | 09:06 AM
sluggo17's Avatar
sluggo17
3rd Gear
Default Crazy C5 HVAC issue
I have a 98 Pace car with automatic climate control. I recently had the compressor and condenser replaced. It seems to work OK but only on the drivers side. Driver side cold - passenger hot. I have tried pulling the HVAC fuses about 20 times and have even disconnected the battery for 12 hours. The crazy thing about is when I go to the DIC, I get 2 history codes, BO367H and BO446H. If I have the car running and clear the codes, the air will turn cold on the pass side for about 10 secs and then warms up again. If I go back to the DIC, the codes are back and they always come back as history codes. I am a little perplexed and really don't want to tear the dash apart. I figure if it works correctly when codes are cleared then the blend door at least is moving. Any suggestions? You expertise would be greatly appreciated. Thanks
Old Jul 13, 2020 | 10:46 PM
SilverC54me's Avatar
SilverC54me
Replace the blend door actuators. Do both the driver and passenger ones at the same time. Use the Dorman 604-106 to replace them.
Gary
Old Jul 14, 2020 | 05:35 PM
sluggo17's Avatar
sluggo17
3rd Gear
Thanks Gary- I've holding out that last hope I wouldn't have to do it but alas I must. I have already replaced the left side. Now for the real work.
Thanks for the reply.
To Crazy C5 HVAC issue
