Engine swap options or rebuild LS1
Old Jul 14, 2020 | 02:47 PM
MatsA's Avatar
MatsA
2024 C6 of the Year Finalist - Modified
Default Engine swap options or rebuild LS1
Seems my Ls1 is giving up it runs but sounds like stone crush piston slap issue.
So what options do i have is the LS1 block something that can be rebuilt ?
Have looked at the LS364/450 GM performance longblock and i like it but it seems it is on backorder every where, is this a good option ?
Also looked into the shortblock ATK and Blueprint 6.0 LQ9 options with various setups that makes it possible to just move all top end and bat pan to new block , but then when you add it all up it will almost be same money as the LS364 option that is a new engine.
I am aiming for 550-600 hp and that includes the A&A V3si kit that i have purchased a year ago, so my best options would be with all this in mind ?
Car is a M6 -02 convertible.
Old Jul 15, 2020 | 04:37 AM
dskinsler83's Avatar
dskinsler83
Do an iron block build and call it a day in my opinion. Spring for ARP studs on the crank and for the heads and turn up the boost!
Old Jul 15, 2020 | 11:44 AM
MatsA's Avatar
MatsA
Yes a restored 6.0L short block with some goodies is like 3000 USD and i could move over all parts from the LS1.
The LS364 have nice heads but internal parts is not that good compared to ATK or Blueprint engines type of shortblocks.
To Engine swap options or rebuild LS1
