Flywheel Holder not lining up?
Old Jul 14, 2020 | 02:52 PM
TDLW's Avatar
TDLW
Default Flywheel Holder not lining up?
I'm making my way through a harmonic balancer change. I've got my starter out of the way and am attaching my flywheel holder to the flywheel. However, I'm concerned that the teeth of the holder arent quite matching up to the teeh in the flywheel as deep as i'd like. I am concerned about cranking down on my HB bolt to loosen it and one, or more, of the teeth on my flywheel breaking off.
Any thoughts?
Old Jul 14, 2020 | 03:26 PM
MetalMan2's Avatar
MetalMan2
Is that with the holder bolts tightened?
Old Jul 14, 2020 | 08:50 PM
Speedy007's Avatar
Speedy007
Hold up here flywheel / crank pulley area I’m confuse here . What’s happening ? Are you talking about the timing gears ?
You did not have to remove a starter to change a harmonic balancer / crank pulley . Remove steering rack , alt, power steering bracket, abs bracket , get some rope to tie the abs out . Move radiator out of way . No need to touch the timing even unless your updating.
Old Jul 14, 2020 | 09:28 PM
feeder82's Avatar
feeder82
He's using a tool that locks the flywheel so you can properly torque the harmonic balancer bolt. You unbolt the starter and place the tool in its place
Old Jul 14, 2020 | 11:55 PM
Speedy007's Avatar
Speedy007
Park and 1st seems to work fine ?
Old Jul 15, 2020 | 02:02 AM
MetalMan2's Avatar
MetalMan2
Not for everyone... I preferred to use the flywheel holder as well. 240 ft-lbs is a lot!
Old Jul 15, 2020 | 01:47 PM
Speedy007's Avatar
Speedy007
Curious how does this tool fit ? From my experience with the car the only way to get at the fly is a headache of work removing the entire rear cradle ,exhaust torque tube ect.
Old Jul 15, 2020 | 02:11 PM
feeder82's Avatar
feeder82
If you get the right tool (some of them are generic and dont fit)it bolts in where the starter did. You only need to drop the exhaust pipe or header.
Old Jul 15, 2020 | 02:17 PM
MetalMan2's Avatar
MetalMan2
Yep, and the starter can just be slide toward the front of the car, no need to disconnect it or anything.
To Flywheel Holder not lining up?
