Odd A/C issue.. Need guidance
Scanned DTC codes, and only 4 History codes seen (all for the AO LDCM & AO RDCM - B2282H, B2283H, and U1064H for each door), and these 4 codes are "completely normal" due to added on door lock & window modules (don't ask, and no need for comment, since both doors function as intended).
2003 LS1 convertible automatic 44K miles
93 deg. day with 95% humdity
Temp setting to max cold. Pass side set to "center".
On "Auto" with Recirculating Air: Max cold reading at center vent = 40 deg. (nice and cold, with no humidity felt).
On "Auto" with Outside Air: Max cold reading at center vent = 60 deg. (and could feel "humidity").
Repeated the above (for about 5 minutes in each switch position), and both times, same results. Air flow / fan output out of each dash vent was considered to normal in both switch positions.
Thanks,
Plasticman
Note: Above temps have been corrected (thermometer reads 3 deg. F high).
Allowing about 5 minutes between each change in settings to let the thermometer to stabilize.
AC up till last year was running properly.
Last year, due to poor AC cooling output, I checked the AC charge, and found it to be low. I added sufficient amount to bring it back up to proper charge based on LOW/HIGH pressures, ambient temp, & humidity at that time (using a dye and sealer version of R134a).
2 weeks ago, I rechecked pressures (all still acceptable), and I checked for any signs of the dye (none).
2 days ago was 1st chance to actually verify that AC was working correctly (due to other projects / health / etc.).
The fact that the AC obtains 43 deg. at the vent in the "Recirculate" mode, and is very comfortable, implies that the AC portion of the HVAC system is operating correctly. It is only when the "Outside Air" mode is initiated, that it fails with a 20 deg. increase in vent temp, with added humidity felt immediately.
From that perspective, I would think that perhaps a HVAC blend door is improperly opening or an actuator is damaged?
I note your concern of: A low charge condition will lead to a portion of the evaporator being warmer and no longer effectively dehumidifying and cooling the hot humid incoming air. I will have to recheck the pressures again, but since the change is so "immediate", when switching from "Recirculate" to "Outside Air", or in the opposite direction, I feel it is not the AC portion of the system that is at fault.
Thanks,
Plasticman
It is possible to have leaks without seeing dye or the amount of dye is quite small. I have a Chrysler that experience this. I don’t drive it much and it sits most of the winter. It experiences “phantom leaks”. I didn’t make this term up. It is something we used to describe customer complaints where they would bring their car in the Spring because the a/c was not cooling. No amount of leak sniffing can find the leak yet the charge leaked out over the winter.
As far as immediately feeling the change, keep in mind that when you are on recirc about 85% of the air is pulled in from your cool comfortable low humidity cabin. When you switch to outside air, you slam that evaporator with 100% hot humid air.
If it was my car, I’d try a half a can of r134a and see if it makes a difference.
39 degrees in recirc and 46 degrees on outside air.
I will add a 1/2 can tomorrow, and hope for the best.
Plasticman
Perfectly normal operation. In recirculate, the system is refrigerating previously refrigerated (i.e. cabin) air. In fresh it's refrigerating the hotter -- sometimes significantly hotter -- outside air. Generally, recirculated will also have greater air flow for a given fan speed, as both input and output air are from/to the cabin. In the fresh air condition the system is adding more air to the closed cabin, creating a bit of pressure as the added air volume has to escape.
Now when you first fire up the car after it's been sitting in the sun, recirculate may well be less cool than fresh, because the cabin air may be much hotter than outside air.
Appears the 1/2 can did the trick!
Results from today: 95-97 F temps, with only 45% humidity, with same operating conditions as before (45 mph, Fan on full, temp on min., reading temp @ center vent).
Recirculate = 38 F Outside Air = 47 F
I say that was "success"!
Will have to see how it performs when the humidity goes back up to our normal 90-100%, but for now I am "happy"...
Thank you,
Plasticman
PS: Previous readings reported have been "corrected". Found that my thermometer reads high by 3 deg. F. Above temps are corrected..
Still have not had the car out again, since the weather has not returned to our typical high temp & high humidity...
Will report back when I get it back out.
Thanks again,
Plasticman
