A/C Issues
Old Jul 20, 2020 | 02:30 PM
DERIII's Avatar
DERIII
Cruising
Default A/C Issues
Was out yesterday in 2000 C5. 100 degree day and after about 2 hours of running the A/C, a slight drip was noticed on passenger side near the front of the door.I could not locate the drain or source and could not get under to look. Any suggestions?
Old Jul 20, 2020 | 02:44 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Not sure where you're located but I'd suspect compensation from the humidity and heat.
Old Jul 20, 2020 | 03:49 PM
DERIII's Avatar
DERIII
Cruising
North Carolina, is there any preventative maintenance I can do to prevent?
Old Jul 20, 2020 | 04:11 PM
DinoBob's Avatar
DinoBob
You mean water dripping under the car?
Old Jul 20, 2020 | 04:43 PM
DERIII's Avatar
DERIII
Cruising
Inside the passenger compartment on the floor towards the dash
Old Jul 20, 2020 | 05:14 PM
ttiros's Avatar
ttiros
Just happened to me. Clean udders and a/c drain. They are clogged.
Old Jul 20, 2020 | 09:13 PM
mstromquist
^^^^This is what I would suggest to start with.^^^^
Old Jul 21, 2020 | 04:59 AM
on what ttiros said. Ensure those items are OK and the water should disappear from inside the car.
And moved over to Tech.
Old Jul 21, 2020 | 07:35 AM
DERIII's Avatar
DERIII
Cruising
Thanks, How do I clear the drain? What are udders?
Old Jul 21, 2020 | 08:15 AM
rrwirsi's Avatar
rrwirsi
Here is a video on cleaning the udders.
Old Jul 21, 2020 | 08:31 AM
DERIII's Avatar
DERIII
Cruising
Wow, thanks so much.
Old Jul 21, 2020 | 08:26 PM
knewblewkorvette's Avatar
knewblewkorvette
Chances are it's the A/C drain.
Old Jul 21, 2020 | 11:34 PM
jim993's Avatar
jim993
This is likely caused by the AC condensate drain being plugged. It is on the passenger side firewall below the exhaust manifold, a 90 degree rubber elbow. Difficult to reach from above, easier from below.
You can see a picture of the 90 degree rubber condensate elbow in post # 7 below. Read through it all.
https://www.corvetteforum.com/forums...nger-side.html
To A/C Issues
