What all is needed for a cam only install?
Old Nov 28, 2002 | 11:54 AM
Joe C5 Coupe's Avatar
Joe C5 Coupe
Default What all is needed for a cam only install?
I did a search but didn;t find all that much. I can't afford the heads right now and it seems people have been getting retty decent results by just changing the cam. So my question is what else do I need besides the cam. I would be going with a mild as close to stock driveabiltiy/idle as possible. What would your recommendations be for the cam as well as what else I need? Happy Thanksgiving guys :cheers:
Old Nov 28, 2002 | 12:10 PM
Barely Legal's Avatar
Barely Legal
Default Re: What all is needed for a cam only install? (Joe C5 Coupe)
You're going to need to change the valve springs. Also, replace the crank snout bolt. In most instances people pull the heads so there is no issue of lifters dropping into the motor. Then you'll need new head bolts and gaskets. Also, antifreeze and oil.
Hardened push rods are a good idea while you're in there too.
Old Nov 28, 2002 | 12:12 PM
C5Noir's Avatar
C5Noir
Cam
Comp Cam 918s (use stock retainers) or Isky 295-Ds (the ultimate drop in single spring)
hardened 7.400" Pushrods
Timing Cover Seal
Crank Seal
Upgrade to a Katech or ARE oil pump for boosted oil pressure :)
JWIS timing chain and Cloyes gears
New CrankShaft bolt
ASP pulley while you're in there
This is a bullet proof setup.
[Modified by C5Noir, 11:13 AM 11/28/2002]
Old Nov 28, 2002 | 12:21 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Default Re: What all is needed for a cam only install? (Barely Legal)
Why the head bolts? LS1 cam can be swapped w/o head removal. :cheers:
Old Nov 28, 2002 | 12:25 PM
C5Noir's Avatar
C5Noir
Default Re: What all is needed for a cam only install? (need-for-speed)
You don't need new head bolts. The only new bolt is the crank bolt is needed.
To What all is needed for a cam only install?
