Help! Code B0338 and B0441
Old Jul 23, 2020 | 10:50 AM
GEMcLean's Avatar
GEMcLean
Default Help! Code B0338 and B0441
I have just replaced both of my HVAC door actuators. I am getting Code B0338 and B0441. There is a two wire connector near the drivers side actuator that I cannot find where to plug in. the other end is near the ignition switch, but I can't find where to plug that in either.
Anyone know how to fix this issue?
Any help would be greatly appreciated. Pictures very well desired.
Old Jul 23, 2020 | 10:54 AM
GEMcLean's Avatar
GEMcLean
I found the plug by the ignition switch, but still cannot find the one near the actuator..
Thanks,
Old Jul 23, 2020 | 02:17 PM
oelarse's Avatar
oelarse
There is only one 5 pin connector for the actuator ( feedbackpotmeter and motor supply).
B0338 Inside Air Temp Sensor Open- Did you disconnected this sensor close to the ignition key ? Your wire and 2 pin connector is probably for this sensor
B0441 Left Actuator Out of Range - Have you tried to index your actuators ( Fuse disconnected for tha HVAC control min 60 sec ) ?
Old Jul 23, 2020 | 06:48 PM
GEMcLean's Avatar
GEMcLean
Found it!
it goes nowhere.
All codes eliminated. Just plugged in the inside air sensor.
Thanks,.
To Help! Code B0338 and B0441
