HELP....I have another annoying little problem
Old Nov 29, 2002 | 05:18 PM
97moneypit's Avatar
97moneypit
Default HELP....I have another annoying little problem
A few days ago a squeak started coming from the steering column. At first I thought it might be something rubbing right behind the steering wheel. It occurs primarily when the steering wheel turns to the right from the 12 oclock position to about 7 oclock. There is no squeak between the 7 and 12 oclock positions.
From inside it sounds like the squeak is right behind the steering wheel at the junction to the column, but this isn't the case. It's definitely coming from inside the engine compartment. I tried to pinpoint it but I can't turn the wheel from that far away. I will have to wait for the wife to get home.
Is this most likely at the gear box?
Anybody else ever have a similar problem?
Old Nov 29, 2002 | 05:53 PM
brewtoo's Avatar
brewtoo
Default Re: HELP....I have another annoying little problem (97moneypit)
My old '97 had that same problem. It wouldn't squeak until the car was warmed up, though.
Even though there is a fix posted here on the forum, I never could really figure out where to put the lubricant.
https://www.corvetteforum.com/techti...D=35&TopicID=1
:cheers:
[Modified by brewtoo, 4:56 PM 11/29/2002]
Old Nov 29, 2002 | 06:02 PM
97moneypit's Avatar
97moneypit
Default Re: HELP....I have another annoying little problem (brewtoo)
Thanks for the post. :cheers:
Old Nov 29, 2002 | 08:01 PM
rrobert22's Avatar
rrobert22
Nope, cant help you. your squeak doesnt match the ten Ive had :lol:
[Modified by rrobert22, 7:02 PM 11/29/2002]
To HELP....I have another annoying little problem
