How To Replace C5 Motor Mounts
Old Aug 4, 2020 | 11:02 AM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Default How To Replace C5 Motor Mounts
This process may very slightly depending on your exhaust setup, but I hope this can help some of you DIYers.
TORQE SPECS:
Sub-Frame (4) 21mm @ 81ft-lbs
Motor Mounts (2x2) 18mm @ 37ft-lbs
Front Sway Bar Bracket (4) 13mm @ 43ft-lbs
Front Sway Barend Links (2x2) 18mm @ 53ft-lbs
Lower Shock Mount (2) 13mm @ 21ft-lbs
Upper A-Arm (4) 16mm @ 48ft-lbs
Intake Manifold (10) 8mm @ 44in-lbs 1st pass, 89in-lbs 2nd pass (SEE TORQUE SEQUENCE)
Fuel Rail (4) 10mm @ hand tight
Throttle Body (3) 8mm @ hand tight
Brake Line Bracket (2) 10mm @ hand tight
Exhaust - depends on your setup
Old Aug 4, 2020 | 12:00 PM
zone-7's Avatar
zone-7
Thanks Chris. Really enjoy your "How To" vids. I also upgraded my motor mounts and found information on LS1Tech very helpful. Well worth the time & effort.
Old Aug 4, 2020 | 02:26 PM
MetalMan2's Avatar
MetalMan2
Thanks for sharing! I have motor mounts in-hand so this is really useful for me.
Have you tried removing the intake manifold with the fuel rail still bolted on? I've had luck doing so, and find that it's one less spot for debris to possibly enter. Also a small bit less work, of course.
Old Aug 4, 2020 | 03:14 PM
wydopnthrtl's Avatar
wydopnthrtl
Thanks Chris. I too enjoy your vids!
Old Aug 4, 2020 | 04:09 PM
Chris Draper
Yes, you can.
Old Aug 4, 2020 | 10:22 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Good vid thanks for posting!
Question. I saw what the old vs new in the video looked like - and they did appear to be worn for sure.
Have you had a chance to drive the old girl post new mount install and get on it & break the tires loose a time or three? What I am getting at is I think a lot of people that think they have wheel hop actually have a little excessive engine flopping around on soft 20 year old mounts - so instead of wheel hop they actually have engine flop.
What say you?
Thanks,
Toys
Old Aug 6, 2020 | 12:44 AM
Moved over to the C5 Tech section.
Old Aug 7, 2020 | 01:30 AM
Chris Draper
What say you?
Thanks,
Toys
Interesting theory, I can see where that may be true. I can also see the transmission mount being the cause for wheel hop.
I have several friends with FD RX7s and one of the main causes for whee hop in those cars is a bad differential bushing that is basically directly above the rear axles and diff, similar to the C5 trans mount.
I have not had a chance to drive the car yet. I’m still in the middle of several other projects, but I’ll report back when I can.
Old Aug 9, 2020 | 11:43 AM
Toys4Life C5
St. Jude Donor '21
It is clear that GM never intended to have the tranny mount provide much if any twisting resistance.
The aftermarket ones do, but even a new GM wont provide much. Wonder what Tadge would say about the aftermarket diff mounts. Wish I could ask him.
Please do report back after a few hard rips as to if you notice a more solid feeling with the new motor mounts. I have used poly mounts on other vehicles in the past and the N/H/V issues made me change them back to stock in a hurry.
To How To Replace C5 Motor Mounts
