How to remove cd changer bracket
Old Aug 9, 2020 | 03:20 PM
hmhaga's Avatar
hmhaga
Default How to remove cd changer bracket?
I thought it would be sufficient to drill out the pop rivets. Then I thought the bolts could be reversed out. Not so. Is it glued in place?
Old Aug 9, 2020 | 06:11 PM
jcgunn's Avatar
jcgunn
I removed the CD changer on my 03 Vert a long time ago. I was able to unscrew the bolts and remove the bracket, it was not glued. I just left the studs. You might try a Dremel with a small cutoff wheel. If you use a drill, be very careful not to drill into the gas tank!
Old Aug 10, 2020 | 03:43 AM
hmhaga's Avatar
hmhaga
This bracket seems to be in another location? This is a FRC/Z06, and the bracket is fixed to the rear plate of the trunk.
Old Aug 12, 2020 | 05:43 AM
hmhaga's Avatar
hmhaga
Anyone? -Don't want to drag unnecessary weight around
To How to remove cd changer bracket
